You are here: PSPad forum > English discussion forum > After applying the settings in the menu program increases
#1 After applying the settings in the menu program increases
Posted by: I like PSPad | Date: 01/22/2017 17:01 | IP: IP Logged
Hello dear author! I'm a fan of your program! I should windows7 32 after applying the settings in the program, it is why the increase in size right on the full-screen menu icons are 10 times more the impression that she swallowed slonasmiling smiley Please tell me that it is necessary to set up so it does not grow in size? ps I am very comfortable to enjoy it because it has a ftp c using this function, I'm on the straight walk into your satellite receiver vu + duo2 and edit files and satellites.xml wicardd.conf passing filezilla.ochen convenient program for me THANK YOU!
#2 Re: After applying the settings in the menu program increases
Posted by: pspad | Date: 01/22/2017 17:10 | IP: IP Logged
Hello. Size of icons in menu (and menu item height too) depends of the Menu icon set settings in Program settings / Program 1
#3 Re: After applying the settings in the menu program increases
Posted by: I like PSPad | Date: 01/22/2017 18:04 | IP: IP Logged
Thank you very much! Now I will try to setup!
