You are here: PSPad forum > English discussion forum > How to stop forced HEX mode
Posted by: zforray | Date: 2016-04-21 15:01 | IP: IP Logged
I have a file I want to view with PSPad. Since it contains hex/packed data, PSPad forces HEX mode while Notepad does not and shows viewable text, which is what I want since I don't want to edit it.
Posted by: vbr | Date: 2016-04-21 15:16 | IP: IP Logged
zforray:I have a file I want to view with PSPad. Since it contains hex/packed data, PSPad forces HEX mode while Notepad does not and shows viewable text, which is what I want since I don't want to edit it.
I believe, disabling the detection of binary files should help in this case (if you aren't editing the file):
Settings: Program settings:
[Direct edit]
in the section Special settings - set:
AutoDetectBinary=0
hth,
Posted by: zforray | Date: 2016-04-21 16:05 | IP: IP Logged
That worked. Thanks.
