You are here: PSPad forum > English discussion forum > Default syntax highlighter for files without extension
Posted by: zelenej | Date: 2016-04-04 15:06 | IP: IP Logged
I would like to set default syntax highlighter (UNIX Shell Script) for files without extension.
What should I add to file format in the highlighter settings? I have tried adding asterisk there (*), but it didn't work.
Chtěl bych si nastavit zvýraznění syntaxe pro soubory bez přípony (Linux/Unixové shell soubory).
Jak mám nastavit masky souborů ve zvýrazňovači? Zkoušel jsem přidávat hvězdičku (*), ale to nefungovalo.
Posted by: pspad | Date: 2016-04-04 16:25 | IP: IP Logged
Set mask to: *.
Dot is important
Posted by: zelenej | Date: 2016-04-04 17:33 | IP: IP Logged
OK, *. works, but not for files starting with dot (.htaccess). Is it possible to do it even for these (Windows 10, 64-bit)?
Edited 1 time(s). Last edit at 2016-04-04 17:34 by zelenej.
Posted by: pspad | Date: 2016-04-04 17:48 | IP: IP Logged
.htaccess isn't file without extension. It's file without name with extension only.
Add it to your highlighter as *.htaccess
Posted by: zelenej | Date: 2016-04-05 08:32 | IP: IP Logged
Thank you, it works! It never occurred to me that "htaccess" is treated as extension..
Posted by: pspad | Date: 2016-04-05 09:11 | IP: IP Logged
in windows world the part behind the last dot mens extension
