You are here: PSPad forum > English discussion forum > PSPad - application is unstable
Goto Page: 1 2 3 Next
#1 PSPad - application is unstable
Posted by: maki | Date: 2014-09-27 20:02 | IP: IP Logged
I opened the text file:
Size 50 MB / 400000 lines
Find: ........
Click Button [COPY]
PSPad long to respond and slow down the system.
670 MB RAM / Non-Stop 25% CPU
#2 Re: PSPad - application is unstable
Posted by: maki | Date: 2014-09-27 20:30 | IP: IP Logged
Hang PSPad (not possible save)-> kill proces -> LOST DATA!sad smiley
Edited 1 time(s). Last edit at 2014-09-27 20:31 by maki.
#3 Re: PSPad - application is unstable
Posted by: pspad | Date: 2014-09-27 20:42 | IP: IP Logged
When you kill process, you will lost data every time, cause application is immediately ended.
How many lines from your 400 000 were copy into new file?
#4 Re: PSPad - application is unstable
Posted by: pspad | Date: 2014-09-27 20:52 | IP: IP Logged
Simulation
I created similar text file as yours: 43MB, 432 000 lines.
Search for string using COPY button
Result of 20 000 lines was finished within 5s
#5 Re: PSPad - application is unstable
Posted by: maki | Date: 2014-09-27 20:56 | IP: IP Logged
only 20k? - so little(!)
#6 Re: PSPad - application is unstable
Posted by: maki | Date: 2014-09-27 20:58 | IP: IP Logged
I dont know !!!
F*ck is impossible to copy - because the application to hangangry smiley
#7 Re: PSPad - application is unstable
Posted by: maki | Date: 2014-09-27 21:00 | IP: IP Logged
I also use EmEditor x64
Where are the similar options[COPY] in the editor. It's important.
Edited 1 time(s). Last edit at 2014-09-27 21:00 by maki.
#8 Re: PSPad - application is unstable
Posted by: maki | Date: 2014-09-27 21:08 | IP: IP Logged
Nonsense, because I have a different (!)
I do not believe you
50 MB / >400000 lines
Edited 1 time(s). Last edit at 2014-09-27 21:09 by maki.
#9 Re: PSPad - application is unstable
Posted by: pspad | Date: 2014-09-27 21:10 | IP: IP Logged
maki:
as usually you are not able to give enough informations. I again wasted my time sad smiley
#10 Re: PSPad - application is unstable
Posted by: maki | Date: 2014-09-27 21:32 | IP: IP Logged
example.
1. I have a text file 1 GB
2. I split the files to 50 MB each
3. Now I want to find all the links (50 MB x 20 files)
4. containing the name of "Y:\NEW" (1000,000 lines)
How to find all the links of 20 text files with that name and add a new table???
It really frustrates me anymore. angry smileyangry smileyangry smileyangry smileyangry smileyangry smileyangry smileyangry smiley
PSPad to suspension or really slow to respond to commands.
I use EmEditor and AkelPad (64-bit)
but I can not find the option COPY and open new TAB ????????????????????????????
Please answer on without asking the next question.
Where are the options to find and copy found another window(TABLE)
Edited 1 time(s). Last edit at 2014-09-27 21:34 by maki.
