You are here: PSPad forum > English discussion forum > How to save all Paths? (partition letter E-Z)
Posted by: maki | Date: 2014-09-23 15:30 | IP: IP Logged
Save TXT file UTF-8
Example FULL PATH
Z:\M\MA\Documents\Porów\Nowy folder (3)\Nowy folder\Nowy folder (2)
S:\Aps\Open\gtr.dll
Script PowerShell or CMD.
Posted by: pspad | Date: 2014-09-23 16:37 | IP: IP Logged
Sorry maki, but I don't want what do you mean.
Where do you want to save whole path?
If you don't want to give complex informations to make your question answerable...
Posted by: maki | Date: 2014-09-23 17:33 | IP: IP Logged
Correct script (CMD)
Problem Unicode UTF-8
"????" <== UNICODE
for %%I in (a b c d e f g h i j k l m n o p q r s t u v w x y z) do (dir %%I: /OGN /S /B /AD >> "C:\List\Folderlist.txt")
Posted by: pspad | Date: 2014-09-23 18:14 | IP: IP Logged
OK. I will try guess meaning of your question.
You created file using PowerShell and you want to open it in PSPad. PSpad doesn't show you content correctly. Right?
Please note, nobody see content of your head. You need to explain things.
Edited 1 time(s). Last edit at 2014-09-23 18:14 by pspad.
Posted by: maki | Date: 2014-09-23 18:35 | IP: IP Logged
pspad:You created file using PowerShell and you want to open it in PSPad. PSpad doesn't show you content correctly. Right?
No. I want to correct the code to properly save unicode font and FULL PATH (unlimited depth + filename.ext)
Edited 1 time(s). Last edit at 2014-09-23 18:36 by maki.
Posted by: pspad | Date: 2014-09-23 18:45 | IP: IP Logged
Do you see? In case you would write yourforst question, you will get simple answer. How much time we will spare?
If you want to save file in UTF-8 or UTF-16, go to menu Format, click on the requested code page and press save.
File will be saved in Code page you see on the status bar. In menu format you can change current Code page to another one.
Posted by: maki | Date: 2014-09-23 19:20 | IP: IP Logged
I want to save all and path to the files on all drives! (letter drive +All folders(subfolders) + all file names +extension)
Is that so hard to understand?
20 different scrypt (Powershell and CMD) does not work as I expected and I am compelled to abandon this idea because this can not be solved.
There's no time for that. Nobody knows what I mean.
Posted by: pspad | Date: 2014-09-23 19:46 | IP: IP Logged
OK. You want to list all files from all your drives. How is it related to PSPad?
Posted by: Andreas | Date: 2014-09-23 22:56 | IP: IP Logged
maki:Is that so hard to understand?
Yes, it's nearly impossible at least for me to understand what you're trying to do and what you're asking. I'm wondering where Jan gets his patience from and waiting for the moment when he will lose it.
Posted by: massimobalestra | Date: 2014-09-23 23:45 | IP: IP Logged
I think we need to plead the cause to make Jan Fiala Saint.
Saint Jan protector of the text editors.
