You are here: PSPad forum > English discussion forum > Re: Creating new file bug in FTP
Posted by: doctorlai | Date: 2014-08-13 12:41 | IP: IP Logged
when I right click and create a new file, if the file name is "___info___.php" the pspad will create a new file "_info_.php" instead.
Please could you check this? It is not so serious bug since I can later rename the file to correct filename.
THanks
Posted by: pspad | Date: 2014-08-13 12:52 | IP: IP Logged
Thank you for report. Tested and confirmed. I will fix it.
Posted by: pspad | Date: 2014-08-13 12:55 | IP: IP Logged
Fixed. Available in the next build.
Posted by: doctorlai | Date: 2014-08-13 21:47 | IP: IP Logged
Thank you for the quick fix. Impressive.
