You are here: PSPad forum > English discussion forum > File Contents were Changed. Reload?
Posted by: Deadbeef | Date: 05/27/2010 13:26 | IP: IP Logged
Windows 7, publishing ASP page on IIS server.
After ASP file is saved AND viewed on the web-server, returning to pspad produces the "File Contents were changed. reload?" message. (Always)
This is very annoying and possible reason to abandon PSPad.
Posted by: pspad | Date: 05/27/2010 14:52 | IP: IP Logged
Deadbeef:Windows 7, publishing ASP page on IIS server.
After ASP file is saved AND viewed on the web-server, returning to pspad produces the "File Contents were changed. reload?" message. (Always)This is very annoying and possible reason to abandon PSPad.
Are you sure that ASP doesn't change last write time stamp? If yes, it's correct that PSPad inform you about file change.
You can switch it off in program settings / Direct edit button
CheckDocChanges=0
Posted by: Lolo | Date: 06/09/2010 15:26 | IP: IP Logged
For me it does not work at all (even with v4.5.5 build 2390).
PSPad does not detect if file is changed outside the editor.
I am on Windows XP sp3
If you need my help to test alternative test version, please let me know.
I will be glad to help you.
Posted by: jd | Date: 07/22/2010 21:24 | IP: IP Logged
Jan,
Is there anything that I can do to help you solve this problem? It is preventing me from using any of the beta versions. Thanks...
-- Jeff
Posted by: dheeraj4uuu | Date: 08/03/2010 07:10 | IP: IP Logged
Posted by: GregDude | Date: 09/01/2010 09:19 | IP: IP Logged
Same issue here, however it only occurs with files on network drive for me. Trying latest dev build now as this post forum.pspad.com suggests it has been fixed.
Posted by: jd | Date: 09/28/2010 23:53 | IP: IP Logged
GregDude:Same issue here, however it only occurs with files on network drive for me. Trying latest dev build now as this post forum.pspad.com suggests it has been fixed.
No, that doesn't fix the problem.
Posted by: swbrains | Date: 10/03/2010 05:22 | IP: IP Logged
Happens quite often for me, too. I was wondering what was going on when switching windows and returning to PSPad and then getting this message to reload. I kept thinking I would some day click Yes and lose my work, but so far I haven't. ;)
Build: 4.5.5 (2395) on Win 7 (64 bit)
Edited 1 time(s). Last edit at 10/03/2010 05:23 by swbrains.
Posted by: samweis78 | Date: 12/06/2010 14:56 | IP: IP Logged
I would like to confirm this issue.
When editing a file (php) on a network drive (served by win xp or Server 2k3), this message appears, after the file is VIEWED in a browser.
Happens here in two different environments.
Looks to me like the CheckDocChanged - Function of PSPad checks wrongly the last access, not the last change of a file on a network drive.
Setting CheckDocChanged=0 helps at this point but I think thats an important feature when working right and I don't want to disable this for in worst case I save over changes from another machine.
I'm using PSPad 4.5.4 (2356) on Win7 Pro x64 machines.
Posted by: jd | Date: 12/08/2010 05:29 | IP: IP Logged
Latest build (PSPad unicode 4.5.5 (2401) English) does not fix the problem.
