You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.5.3 (895) English - full version
Posted by: pspad | Date: 2026-11-02 10:09 | IP: IP Logged
PSPad 5.5.3 (895) full version was released
www.pspad.com
Edited 1 time(s). Last edit at 2026-11-02 19:30 by pspad.
Posted by: PGomersall | Date: 2026-11-02 15:59 | IP: IP Logged
Jan, thanks for this. 2 things:
1) Typo in this new release thread; the title in the english topic has the old (891) version number.
2) On your English main home page the release date says September 2, not November
Edited 1 time(s). Last edit at 2026-11-02 16:00 by PGomersall.
Posted by: pspad | Date: 2026-11-02 19:31 | IP: IP Logged
Thank you, fixed.
If you have some wishes or ideas, please write them into Future plans topic:
forum.pspad.com
Posted by: DelphiErik | Date: 2026-11-10 11:53 | IP: IP Logged
When using IDE styles (not classic Windows), there is some repainting-issue of the outer-borders of the editor: after some time the small bands on the right of the vertical scrollbar and below the horizontal scrollbar are getting messed-up. Minimizing and restoring the main window fixes this but after a while the issue is back. This issue was also there in previous versions. See the red marks in this image: postimg.cc
PSPad 32b 5.5.3 build 895.
Posted by: pspad | Date: 2026-11-10 12:58 | IP: IP Logged
I will use PSpad with styles and pay attention to this behavior.
Some things about drawing problems has been fixed already in 6.0.0 builds (developer forum), but it you want test it, wait for this weekends build.
Posted by: DelphiErik | Date: 2026-11-10 13:28 | IP: IP Logged
I found out it's quit easy to reproduce: just maximize and restore the main window to a smaller size. Then you'll see the repainting-issue (the file in the editor should be big enough to show the horizontal and vertical scrollbars).
Does version 6 still work with JScript scripts? I did not test in yet. I use "fillcols.js" by John Hendrickx a lot. Perhaps you could improve/expand the block manupulation in PSPad? Like filling a block with numbers (like in PSPad's Lines Manipulation > Numbering) but then for columns (and automatic left/right alignment). Or fill columns with a static text. Like in Notepad++. But I prefer PSPad
Thanks!
Posted by: pspad | Date: 2026-11-10 13:47 | IP: IP Logged
Looks like it's fixed in my internal version already
