You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.5.3 (891) English
Posted by: pspad | Date: 2026-10-24 09:23 | IP: IP Logged
sourceforge.net
PSPad 64 bit version doesn't contains scripting. In case of any problem use 32bb version.
SHA1 hash:
250b451063e55ef3d1c55aefe521ab8b43339d21 pspad553b891.zip
fc6918d036cc0cf343dc0755412b86c41726020a pspad553b891x64.zip
Changes to 5.5.3 (883)
News:
Backup - new backup style: file.ext.date-time with 10 versions. Backup into the designated folder was separated from the backup styles
64b version - IDE style support + added new styles
%ProjectRoot% - new variable contains Project Default directory value
Program settings / System integration - new button reregister Windows context menu integration
PowerShell, Go - new internal highlighters including code folding and code parser
DockerFile - new user highlighter definition
Minimap - show minimap from the menu View
Removed:
TopStyle - hasn't been developed over 10 years
Project load with active WordWrap
LOG with dark style has black font
Exception after program close when IDE style is switched off in settings
Other fixes reported by users
Posted by: PGomersall | Date: 2026-10-24 17:47 | IP: IP Logged
Hi Jan,
There is a language issue with the tooltip for the icon that looks like a T in a triangle badge when PSPad set to English: "Editiovat CSS soubor nebo oznaceny text v TopStyle".
Not sure if it is in earlier versions than this one.
Edited 1 time(s). Last edit at 2026-10-24 17:47 by PGomersall.
Posted by: pspad | Date: 2026-10-24 19:36 | IP: IP Logged
It was TopStyle integration.
This functionality was removed, because TopStyle as CSS editor wasn't maintained over 10 years.
Did I forget to remove tool button or menu item from somewhere?
Posted by: PGomersall | Date: 2026-10-24 23:17 | IP: IP Logged
Jan, The button\icon is on the toolbar Jan; you may need to check a clean portable setup. Could this be inherited from previous zip\portable configuration as I just overwote the previous download with the new files?
Pete
Posted by: PGomersall | Date: 2026-10-25 01:51 | IP: IP Logged
Jan the button image for TopStyle is still in the bmp files.
Pete
Posted by: pspad | Date: 2026-10-25 03:27 | IP: IP Logged
PGomersall:Jan the button image for TopStyle is still in the bmp files.
Pete
Remove the button means fix all following image indexes in whole application. Easier is replace the icon in future.
I will remove the tool button.
