You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.5.3 (881) English
#1 PSPad unicode 5.5.3 (881) English
Posted by: pspad | Date: 2026-10-09 13:01 | IP: IP Logged
sourceforge.net
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting. In case of any problem use 32bb version.
SHA1 hash: c3c78ffac10cee151a201cc9e25b97c3d53880d8 pspad553b881.zip d4982b1e47a2256a5d858c6ea3e80a10ab20b7df pspad553b881x64.zip
Changes to 5.5.3 (875)
News:
AI support - new user highlighter specification and user scripting (PSPad 32b) for AI in the new subfolder Docs. Attach it to prompt and instruct AI to create new syntax or new script based on the attached specification
User settings - in case PSpad is installed into system protected folder (e.g. Program files), changed files like color schemes, scripts, syntax definitions... will be stored in user profile %appdata%\PSpad. Files in this folder and will be loaded with higher priority than Default ones.
Updater - removed dependance of the OpenSSL, clearer update instruction
AviSynth - new user highlighter definition added nested comments [* ... *] in the user highlighter definition
Autocomplete logic changed - automatical start (after delay) will occur after 2 chars. It will always show list even there is one item. It will never rewrite your text automatically
FTP - possibility to define File tab color based on FTP server in the edit FTP connection settings dialog
Shellextension - to Unregister/Register it use CMD schripts from the .\Docs subfolder. For more informations how the Windows explorer shell extension works read the .\Docs\PSpad shell extension alchemy.txt
Optimalization and speed up application start - highlighters are created on demand, not all at PSPad start
WebView (Edge) is set as default preview browser for HTML
HTML, XHTML highlighter - entities on the start of the line or entities right behind each other
SpellCheck, Add accent marks function works with words starts with accented char too
File list - click on the modified column header
Bookmark icon size in the Search menu or in the Bookmark list window coresponds to the menu icon set size
Other fixes reported by users
#2 Re: PSPad unicode 5.5.3 (881) English
Posted by: LouCypher | Date: 2026-10-12 08:35 | IP: IP Logged
Many thanks for the update, just 2 short comments regarding the scripts for shell extension handling: The unregister script has the same content as the register script. The line adding the app package has a problem with enclosing quotes around the command starting with a double quote but closing with a single quote.
#3 Re: PSPad unicode 5.5.3 (881) English
Posted by: pspad | Date: 2026-10-12 08:47 | IP: IP Logged
Thank you.
The correct unregister script content should be:
REM unregister PSPad shell extension REM run CMD as administrator powershell -NoProfile -Command "Get-AppxPackage -Name JanFiala.PSPad | Remove-AppxPackage" regsvr32.exe /u /s "%~dp0..\pspshellx64.dll" taskkill /F /IM dllhost.exe taskkill /F /IM explorer.exe start explorer.exe
Register script:
REM register PSPad shell extension REM run CMD as administrator regsvr32.exe /s %~dp0..\pspshellx64.dll powershell -NoProfile -Command "Add-AppxPackage -Path '%~dp0..\pspshellx.msix' -ExternalLocation '%~dp0..\'" Rem Restart explorer to make changes available taskkill /F /IM explorer.exe start explorer.exe
Edited 2 time(s). Last edit at 2026-10-12 08:55 by pspad.
