You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.5.3 (875) English
#1 PSPad unicode 5.5.3 (875) English
Posted by: pspad | Date: 2026-10-04 21:18 | IP: IP Logged
sourceforge.net
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting. In case of any problem use 32bb version.
SHA1 hash: d46df8ef532c432285139009a982280a477bec76 pspad553b875.zip 23afc241e2b68c1aeb8d3a3edb75f7e1d42c3b7a pspad553b875x64.zip
Changes to 5.5.3 (873)
News:
Windows Explorer context menu integration directly in menu, for Windows 11 26h2 registration in the APP extension. Steps: in the Program settings / System integration switch to Registry integration and Apply. Rewrite pspShellx64.dll with the one from ZIP, in Program settings switch back to DLL registration and confirm.
Windows Shell Script highlighter - escaped brackets highlighting + many other reports
Macro and assigned shortcuts
* char with Delete Word (Ctrl+Del) function
Other fixes reported by users
#2 Re: PSPad unicode 5.5.3 (875) English
Posted by: nspp | Date: 2026-10-05 07:52 | IP: IP Logged
Updater get 877 version ??
#3 Re: PSPad unicode 5.5.3 (875) English
Posted by: pspad | Date: 2026-10-05 07:55 | IP: IP Logged
Sorry, my typo in the version info on the web for updater. Correct build is 875
