You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.5.3 (873) English
Posted by: pspad | Date: 2026-09-25 11:03 | IP: IP Logged
sourceforge.net
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting. In case of any problem use 32bb version.
SHA1 hash:
6863210bc8f6cd297522b12e42e05bc90fcc955c pspad553b873.zip
97db83f88870c80b2894d16990ce3340ebebba83 pspad553b873x64.zip
Changes to 5.5.3 (869)
News:
FTP - communication library - OpenSSL was replaced with CryptLib. Delete libcrypto*.dll and libssl*.dll. Please test your FTP connections.
FTP - SFTP support added - choose FTP/FTPS or SFTP in FTP connection settings
Sort function - possibility to store/load sort profile. Stored in the Recent.ini file
64b version - system dialogs localization
UTF-8 no BOM - changed detection to prevent false positive detections
Join Lines, Split Lines now offer posibility to enter delimiter string with history. \t means real tab
WordWrap symbol - symbol background is the same as line numbers
Problem with select word with double click in some highlighters
Running action dialog was displayed over other dialogs
Program exit or file close - exceptions joined to code folding
Other fixes reported by users
