You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.5.3 (869) English
Posted by: pspad | Date: 2026-09-21 08:04 | IP: IP Logged
sourceforge.net
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting. In case of any problem use 32bb version.
SHA1 hash:
ca069f4290453537bcdbda17ebaa847f771d990b pspad553b869.zip
d92cb8d1990e2bef9b47f629cc181ca99f49dd6f pspad553b869x64.zip
Changes to 5.5.3 (865)
News:
Using AI translated missing localization strings in translation files
First run should load localization, corresponding to Windows primary language
File tabs - visual separation for better visibility
Menu flickering after start
Redraw problem after icon set change
Code explorer for Assembler - automatic sort
64b version - fixing exceptions
Other fixes reported by users
