You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.5.3 (861) Cesky
#1 PSPad unicode 5.5.3 (861) Cesky
Posted by: pspad | Date: 2026-08-26 09:47 | IP: IP Logged
Odkazy ke stažení, doporučuji 32b verzi:
sourceforge.net
PSPad 64 bit je EXPERIMENTÁLNÍ. Verze zatím neobsahuje skriptování. V případě problémů použijte 32b verzi.
SHA1 hash: 41a7116991119db00bab2939a4a725b0a6e05cdd pspad553b861.zip 7ec6acd7344ac1ac88a821be91a9e7a68d841fc3 pspad553b861x64.zip
Změny od verze 5.5.3 (857)
Novinky:
Program settings / Files - ignore list can contain wildchars (*, ?)
MS Shell Script highlighter, Pas, SQL (MS SQL, Oracle), C#, Java, PHP, Java Script, HTML - updated keywords
PAS Code explorer - click in the Explorer sends you directly into the implementation
Code Explorer - new action in the context menu - Copy path to Clipboard
Code Explorer - as Hint is now displayed path on the second line
Compilation or Run external application doesn't save automatically new files
Search in files - search/replace in open files
Other fixes reported by users
