You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.5.3 (857) English
Posted by: pspad | Date: 2026-08-21 10:17 | IP: IP Logged
sourceforge.net
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting. In case of any problem use 32bb version.
SHA1 hash:
2a4893fc614b0eeace9428742c6056353a16e30e pspad553b857.zip
050febff5405216314da0edde0b2f153de58f25b pspad553b857x64.zip
Changes to 5.5.2 (852)
News:
Splitted window - occurences of the selected text are displayed in both parts
MarkDown - new highlighter, include HTML preview using F10 from HTML menu
Removed:
ChatGPT
PHP highlighter - dblclick selects variable including $
Python highlighter - select text inside brackets function didn't work inside {xxx}, even they were part of string
Compilation - PSPad will automatically switch to tab with reported error in LOG
Complete StatusBar redraw when PSPad is activated - prevent blurry StatusBar
PSPad start - the file tabs order is preserved from last program exit
File exist query - focus is set to modified fileExternal program execution in case when LOG file was fill in
Program settings / KeyMap - overlapping section list with shortcuts
Minimize to Tray icon
Load project - file tabs
64b version - fixing dialog exceptions
Other fixes reported by users
Posted by: Piotr | Date: 2026-08-23 07:25 | IP: IP Logged
Clicking F10 causes the editor windows to open uncontrollably.
Only CTRL + ALT + DEL helps.
Win 10
Edited 1 time(s). Last edit at 2026-08-23 07:25 by Piotr.
Posted by: Piotr | Date: 2026-08-23 07:57 | IP: IP Logged
I restarted my computer.
I opened the editor.
I used F10.
One window opened, but the editor crashed.
Posted by: pspad | Date: 2026-08-24 05:58 | IP: IP Logged
Piotr:Hi,Clicking F10 causes the editor windows to open uncontrollably.
Win 10
What highlighter is active when you press F10?
I tested it with 3ěb version and can't confirm. I wasn't be able to simulate it
