You are here: PSPad forum > Developer forum - new builds > New Extensions
Posted by: andrew | Date: 2026-06-19 08:33 | IP: IP Logged
Hi, I am using PSPad to complement VS Code.
These are the extensions which I think should be added into PSPad - Haskell, Golang, Scala, R, Julia, and Oberon+.
Just for your thoughts.
Posted by: pspad | Date: 2026-06-19 09:20 | IP: IP Logged
Extension = Syntax?
User highlighter (syntax definition) for Haskell, R, Oberon exists. Assign it.
Golang, Julia and Scala don't exists, but PSPad allows you add new syntax highlight.
All you need is list of keywords
