You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.5.2 (843) English
Posted by: pspad | Date: 2026-08-20 07:55 | IP: IP Logged
DelphiErik:StatusBar - DoubleBuffered.
This 'error' is in this build but also in all previous builds:
When I have PSPad open for a long time (say a few hours), the texts in the statusbar are getting a bit blurry (almost like a bold font). This is in the classic Windows IDE style.
You can fix this in Delphi by setting the TStatusBar property DoubleBuffered to TRUE.Thanks.
I will add complete StatusBar redraw when PSpad window is activated (switch from another aplication)
Posted by: pspad | Date: 2026-08-20 08:01 | IP: IP Logged
DelphiErik:Hi, build 843 does not automaticly switch to the correct tab on compile-error, build 833 did work correct.I use PSPad to compile my project by calling an external compiler (batch). Normally (build 833), when an error is found, PSPad would log the error in the Log window and switch to the tab (file) with the error (red line on error-line).
Build 843 only shows the error in the Log window but does not automaticly switch to the tab (file) with the error.
For now I'm going back to build 833.
I hope it will be OK in the future build
