You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.5.2 (833) English
Posted by: pspad | Date: 2026-01-14 11:33 | IP: IP Logged
sourceforge.net
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting. In case of any problem use 32bb version.
SHA1 hash:
24a98b0cb165119390255c96fbfbd532491c372a pspad552b833.zip
3ef14238ce26a40779e138a0fb96f70b46aee143 pspad552b833x64.zip
Changes to 5.5.1 (831)
News:
Scroll to the left/right with Shift+Mouse wheel in editor area
JavaScript - added support for "async" (code explorer + highlighter)
Search in files result - fixed problem if file path contains square brackets
File tabs - name of the active file was till end of the tab
Font size problem, if user increases font size only in the operating system system settings
Other fixes reported by users
Posted by: Freeman | Date: 2026-01-21 22:03 | IP: IP Logged
This version displays large fonts in main menu (forgot to check popup ones). Rolled back to the 831.
Windows 7, 111% (custom) font scale on 2560×1440 monitor.
Posted by: pspad | Date: 2026-01-22 03:56 | IP: IP Logged
Hello. Can you send me screenshot please?
Posted by: Sam8 | Date: 2026-01-23 11:05 | IP: IP Logged
Norton Antivirus is blocking this version. It says risk of ransomware. Please send it to Norton to report as false positive.
Posted by: Jonny | Date: 2026-01-25 13:22 | IP: IP Logged
Hello PsPAd,
Thank you so much for the time spent to fix the problem with the right brackets in the project's file paths.
I tried the new version, 5.5.2 (833) just released, but unfortunately the problem is still there.
In my project, there are many path like this with square brackets, here there are some:
J:\[Lavora]\[Progetto]\Library LibreOffice\[Reference]\[Template]\
J:\[Lavora]\[Progetto]\Library LibreOffice\[Resource]\
J:\[Lavora]\[Progetto]\Library LibreOffice\[Template]\
And i f I search a word, the search correctly finds what I'm looking for, but the links it displays in the results window when clicked opens alweay empty windows, without title that contains nothing.
Posted by: pspad | Date: 2026-01-26 08:18 | IP: IP Logged
Sam8:Hello,
I tried it, but all attempts to report file or URL end with error.
Posted by: pspad | Date: 2026-01-29 14:04 | IP: IP Logged
Freeman:This version displays large fonts in main menu (forgot to check popup ones). Rolled back to the 831.Windows 7, 111% (custom) font scale on 2560×1440 monitor.
I won't touch font size on Windows older than Windows 10.
Posted by: Jonny | Date: 2026-02-13 22:54 | IP: IP Logged
Hi PsPad,
forgive me, but I think I wrote the previous message badly.
I meant to tell you that the problem of searching in projects that use square brackets in the file paths remains the same, you cannot open the corresponding file by clicking on the search results
