You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.5.2 (831) English
Posted by: Alain75 | Date: 2025-12-01 22:11 | IP: IP Logged
It is not a regression from version 5.5.1 or any lower one. But PSPad doesn't recognize async functions of Javascript and doesn't include them in code explorer.
Syntax is :
async function functionName(parametersList) ...
Thanks a lot if you can fix it !!!
PS: Sorry I have create by mistake another post forum.pspad.com you can delete...
Posted by: Alain75 | Date: 2025-12-01 22:14 | IP: IP Logged
It is not a regression from version 5.5.1.
From times to times, when clicking on a line of the log panel result, you don't see the line in the main panel. The reason is that the selected line is under the log panel !!!
It should be fine to automatically scroll the main panel to position the selected line above the top of the log panel.
PS: I created the same post by mistake here forum.pspad.com, you can delete it as I can't
PPS: PSPad is still really a great editor I used more or less every day
