You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.5.2 (831) English
Goto Page: 1 2 Next
#1 PSPad unicode 5.5.2 (831) English
Posted by: pspad | Date: 2025-07-10 11:10 | IP: IP Logged
sourceforge.net
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting. In case of any problem use 32bb version.
SHA1 hash:
ebb69b22cf6715940d7b1c6caf4451c880515b87 pspad552b831.zip
274043a5e9daa24ef72f32271283eb0687954464 pspad552b831x64.zip
Changes to 5.5.1 (825)
News:
PowerShell - added support for here-strings (@'...'@, @"..."@)
MAD-Assembler support added including code explorer support
For new PSPad instance (parameter -N or multiinstance option enabled), PSpad doesn't reopen last opened files for second and other instances
New version of OpenSSL libraries 3.4.1
URL highlighter doesn't recognize e-mail starting with number
Other fixes reported by users
#2 Re: PSPad unicode 5.5.2 (831) English
Posted by: tmpad | Date: 2025-07-14 19:32 | IP: IP Logged
I repeat my question about version 5.5.1 (817):
Any news on the editor engine replacement or the chinese/strange character problem?
The latter is still the most important problem.
#3 Re: PSPad unicode 5.5.2 (831) English
Posted by: pspad | Date: 2025-07-15 09:17 | IP: IP Logged
I want to give chance to the new version of the Synedit component. I cooperate with authors - INI highlighters support was added last week.
There is used new page drawing system. I hope it will help speed up drawing and remove flaws what can possibly occurs during call drawing.
On the other side, I have less free time, so progress is much slower I supposed.
#4 Re: PSPad unicode 5.5.2 (831) English
Posted by: Jonny | Date: 2025-08-19 09:40 | IP: IP Logged
Hello PsPad
First of all, thank you so much for your incredibly useful software, which I've been using with satisfaction for years!
Unfortunately, I have to say that I can't abandon PsPad version 5.0.6.589 for the newer versions, as the search function in the newer versions doesn't seem to work, at least for me!
When I open a project with many files and folders, if I search for a word in all the files, the newer versions of PsPad find the word correctly, but the links it displays in the results window when I click them don't lead anywhere. It always opens a nonexistent file, titled the number of open tabs, and the file contains nothing.
What could have caused this?
#5 Re: PSPad unicode 5.5.2 (831) English
Posted by: pspad | Date: 2025-08-19 11:27 | IP: IP Logged
Thank you for info.
Is the link displayed in the result correct? Do you see whole path?
Can you send me screenshow with the search result?
#6 Re: PSPad unicode 5.5.2 (831) English
Posted by: Jonny | Date: 2025-08-19 12:20 | IP: IP Logged
Hi PsPad
Thanks for your time!
The links shown on the search results page are correct, and they open the indicated files in Windows Explorer.
All the files found by the search are also correct, the contains the searched word.
This is the print screen:
i.postimg.cc
This is the contents of the results page:
fromsmash.com
#7 Re: PSPad unicode 5.5.2 (831) English
Posted by: pspad | Date: 2025-08-19 13:01 | IP: IP Logged
I see the problem - square brackets.
PSPad counts, that in square brackets is number of finds. It removes square brackets and it's content.
It should be easy to handle - I will go from the end or I will use other format to show number of finds.
Can you please tet it with other project what doesn't use square brackets in folder names and confirm it to me?
#8 Re: PSPad unicode 5.5.2 (831) English
Posted by: Jonny | Date: 2025-08-19 13:26 | IP: IP Logged
Yes, you were right.
I modified a project by removing files and directories with square brackets, and now the search works correctly.
The links now open the correct file, in the correct row and column!
Will it be a complex change?
P.S.
I use square brackets a lot to indicate directories with template files, so I can always create files with the same style.
#9 Re: PSPad unicode 5.5.2 (831) English
Posted by: pspad | Date: 2025-08-20 04:45 | IP: IP Logged
I will fix it.
#10 Re: PSPad unicode 5.5.2 (831) English
Posted by: MarkRH | Date: 2025-08-24 05:05 | IP: IP Logged
I've managed to make this version crash repeatably. While I am editing a .php file, I turn on line-wrapping. Then if I type "<div>" at the beginning of a new line, it crashes.
If I do NOT turn on line-wrap mode, it does not crash.
Looks like typing "<strong>" or "<p>" will also cause it to crash. Also does it with .shtml files.
I kept getting a dialog box blocking the crash submitter so I took a screenshot if you need to look at it.
Mark H.
Goto Page: 1 2 Next
