You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.5.1 (790) English
#1 PSPad unicode 5.5.1 (790) English
Posted by: pspad | Date: 2023-06-12 10:02 | IP: IP Logged
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting. In case of any problem use 32bb version.
SHA1 hash:
ea854e11734d5ea66cfd89c66dbe70ccff5bbbfa pspad551b790.zip
927202b54a505d08af0ff01944c8dd8c42c20f9a pspad551b790x64.zip
Changes to 5.5.1 (787)
News:
DeleteWord (Ctrl+DEL) command beavior change
ChatGPT window uses current editor font size
When Trim trailing spaces option was enabled and file was in ReadOnly mode, block selection caused trimming and marking file as modified
Start PSpad with big file as parameter and decline approval to open file
Prevent situation to set zero width of File explorer columns
Handled PSPad_FTP.ini file is write protected
Ctrl+DblClick in the editor window for select text inside quotation marks
Other fixes reported by users
#2 Re: PSPad unicode 5.5.1 (790) English
Posted by: Freeman | Date: 2023-06-17 11:22 | IP: IP Logged
Thanks for the fix.
But now, being pressed in the end of line, Ctrl+Del does nothing while I expect deletion all whitespace until next line, in result line join.
Two other things relate to file open:
* When file is opened from the command line or Windows Explorer by existing instance of PSPad, it doesn't blink his window on the taskbar. PSPad 4.x did that.
* Same as previous, when file is opened externally, and many tabs already exist in PSPad, it sequentially activates them one-by-one with window redraw, and activates opened file tab only after that. Not so annoying, but looks weird.
#3 Re: PSPad unicode 5.5.1 (790) English
Posted by: Piotr | Date: 2023-06-20 08:23 | IP: IP Logged
Freeman:
I confirm
#4 Re: PSPad unicode 5.5.1 (790) English
Posted by: Gabriel_ACE | Date: 2023-06-22 16:18 | IP: IP Logged
where is thats option? i can't find it
#5 Re: PSPad unicode 5.5.1 (790) English
Posted by: pspad | Date: 2023-06-22 18:08 | IP: IP Logged
This is automatically when you open chatgpt window. There is no option
#6 Re: PSPad unicode 5.5.1 (790) English
Posted by: Gabriel_ACE | Date: 2023-06-23 14:20 | IP: IP Logged
ahhh ok
I understand! when you change size, the windows do the same, excelent! THZ
#7 Re: PSPad unicode 5.5.1 (790) English
Posted by: Gabriel_ACE | Date: 2023-10-31 11:58 | IP: IP Logged
I frequently experience that the LINK.INI file gets deleted, to the point that I'm saving a backup for when that happens, could you please check that error?
#8 Re: PSPad unicode 5.5.1 (790) English
Posted by: pspad | Date: 2023-10-31 12:07 | IP: IP Logged
I will look at it.
