You are here: PSPad forum > Developer forum - new builds > Export formated textsh
Posted by: pspad | Date: 2023-03-26 13:26 | IP: IP Logged
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting yet.
SHA1 hash:
5b4436809fc4c05fbcc89ca69456b8e29d19b50d pspad551b783.zip
a12c2d0bf387b7023d1fc4a944b216245f7d82c9 pspad551b783x64.zip
Changes to 5.5.1 (779)
News:
Skin support is back in 32b version
Reformat HTML/XML calls Code Explorer refresh
Export formated text (menu Edit) doesn't export background color
LineEnd problem on the end of the file
Other fixes reported by users
Posted by: Freeman | Date: 2023-03-27 17:03 | IP: IP Logged
Thank you for the build.
Little notice: ChatGPT was made by company named OpenAI ← in one word. Being written with a whitespace, it looks like “(do) open AI (of) ChatGPT”. I've tried to find corresponding string in translation file with no success.
Posted by: pspad | Date: 2023-03-27 18:16 | IP: IP Logged
I will fix it.
Posted by: tmpad | Date: 2023-03-27 19:39 | IP: IP Logged
In the "English discussion forum" you wrote about the "Chinese characters issue":
Quote:Yesterday I made another changes what can cause this problem. It will be available in the next developer build
I think it could help to know what was changed so we can look out for situations where it should not occur anymore.
Posted by: pspad | Date: 2023-03-27 20:19 | IP: IP Logged
What I know:
I happened when you load file.
Most of the cases was related to the PHP highlighter and FTP, often when standalone close bracket was in file.
I made some fixes in hihglighters, I made some fixes in IDE to prevent flickering e.t.c.
Posted by: Greg | Date: 2023-03-27 21:40 | IP: IP Logged
Export formated text works nicely. Thank you again.
Posted by: Ravelli | Date: 2023-03-30 11:48 | IP: IP Logged
Today I'm looking into compiling PHP files directly from PSPad, because it should be faster than switching to the web browser every time.
A) The "Compiler Example" for PHP in your Help file isn't up-to-date. This is working for me:
Compiler: drive:\path\php.exe
Parameters: "%File%"
[X] Capture Program Output Window
[X] Compile on background
LOG parser: *on line %L
So, quotation marks added and the "b" removed.
Here a Screenshot
B) In your "Highlighter Settings" under "Compiler" I don't understand the difference between "Capture Program Output Window" and "Compile on background", where the second one isn't explained in the Help file - maybe you can add it.
But I found, that with "Compile on background" enabled PSPad shows a little feedback in the console: "Process completed, Exit Code 0. Execution time: 00:00.072". This is great, because with "Compile on background" disabled the console remains totally blank. So I added it also to my compiler example above.
C) In your "Highlighter Settings" under "Log Parser" one can see six variables listed. In your Help file under "Compiler Settings" %S and %E aren't explained. Maybe you can add those, and explain what "%E/end parsing" is good for - maybe with an example.
More to come.
Friendly greetings
Ravelli
Posted by: Ravelli | Date: 2023-03-30 12:59 | IP: IP Logged
about A) above: "With Compile on background" enabled I get all the printed text into the PSPad console, e.g. from "echo" commands, which is usually the entire HTML of a website. And this can be a lot, and will disturb in the log console. So, it might be better to keep "Compile on background" disabled for the "Compiler example", although this isn't a good way still, because console remains blank after compiling without any error.
So, I suggest this as new compiler example:
Question: Which program is generating the output "Process completed, Exit Code 0. Execution time: 00:00.072"? Is this from PSPad or the compiler? Screenshot
Posted by: Ravelli | Date: 2023-03-30 13:11 | IP: IP Logged
p.s.: forget it, even with "Compile on background" it outputs all echos. Whatever I select there, the result isn't usable. It is the same with compiling Java, as we discussed a while back. I suggest to either remove this entire compiling section from PSPad, or get it finally working.
Friendly greetings
Ravelli
Posted by: Ravelli | Date: 2023-03-30 15:03 | IP: IP Logged
This is a nasty bug:
When I type a "x" somewhere into a new line of PHP code and wait a moment to get the Autocomplete window popping up, the compile button becomes disabled/inactive in the moment, when I remove the Autocomplete window again, e.g. by clicking with mouse into code, hitting Enter or ESC.
To activate the button again, I have to open "Highlight Settings" once and close the window again.
Apparently this happens only, when the PHP file is using the "HTML multihighligther". In this case, the button should be either always enabled, always disabled, or when hit a window should pop up giving instructions on what to do.
I will send you a short video via email clip documenting it.
Btw: For "HTML multihighligther" the proper English spelling would be "HTML Multi-Highlighter".
