You are here: PSPad forum > Developer forum - new builds > Re: Program settings / Keymap - edit editor shortcuts
Posted by: pspad | Date: 2023-03-24 10:57 | IP: IP Logged
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting yet.
SHA1 hash:
224f2f0bed256a4e2bb3dff265728a3959ffb6a2 pspad551b779.zip
dd874c28aafe9574fac3b388986871ae05f56f4c pspad551b779x64.zip
Changes to 5.0.7 (775)
News:
Google analytics was replaced with Matomo, running on pspad.com server, tracking start and exception only without any user personal details.
New option in Program settings / Direct edit ([Special settings] section) - BreakFTPConnectionEach=15. It breaks popup list of connection after each 15 (or whatever you set). Settings this variable to zero won't break popup list of connections
New option in Program settings / Code folding - Modified line indicator width. If set to zero, indicator is switched off
TextDiff drop window will appear on the position where you drag file into PSPad.
New command line parameter -I or /I tells PSPad to use specific folder with config files. You can use system variables like %USERNAME%
Print to file and file name dialog was canceled caused exception
ChatGPT exception after timeout, fixed output formating
Inno Setup highlighter
File List in the Window menu raised exception
Other fixes reported by users
Posted by: Greg | Date: 2023-03-24 16:48 | IP: IP Logged
Bonjour,
I tested again shortcuts edition.
1) I start PSpad, i use use Default button in the program settings / Keymap ans restart PSpad
2) I go to program settings / Keymap and i see this in Editor :
CopyLineDown Shift+Alt+Down
CopyLineUp Shift+Alt+Up
MoveLineDown Alt+Down
MoveLineUp Alt+Up
3) I clic button OK and try those
4) CopyLineUp and CopyLineDown work, MoveLineDown and MoveLineUp doesn't work
But MoveLineDown ans MoveLineUp work with Ctrl+Alt+Down and Ctrl+Alt+Up
5) I go to program settings / Keymap and define this in Editor :
CopyLineDown Ctrl++
CopyLineUp Ctrl+-
MoveLineDown Shift+Alt+Down
MoveLineUp Shift+Alt+Up
6) I clic button OK and try those
7) CopyLineUp and CopyLineDown works, MoveLineDown and MoveLineUp doesn't work
Editor has problems with Ctrl++ and/or Ctrl+- it seems
I don't know if it's linked but i think Keymap save differents shortcut considering the keyboard :
- QWERTY : Ctrl + + = Ctrl + Num +
- QWERTY : Ctrl + - = Ctrl + Num -
- AZERTY : Ctrl + + = Ctrl + + (PAVE NUM.)
- AZERTY : Ctrl + - = Ctrl + - (PAVE NUM.)
Posted by: pspad | Date: 2023-03-24 16:58 | IP: IP Logged
Alt+Down, Alt+Up are used to move next/previous bookmark. It means editor shortcuts are overwritten by application shortcuts
Posted by: Greg | Date: 2023-03-24 17:16 | IP: IP Logged
I wanted to put formatted text on MS Word but when i paste it's not the entire line with background color but just the word's background color.
ScreenShot 1 : code in PSpad : www.dropbox.com
ScreenShot 2 : Paste in MS Word : www.dropbox.com
ScreenShot 3 : Paste i would like to have : www.dropbox.com
Posted by: Greg | Date: 2023-03-24 17:20 | IP: IP Logged
You're probably right about this bug.
It's a new one. With all my tests on Editor Section, i didn't see that.
Edited 1 time(s). Last edit at 2023-03-24 17:22 by Greg.
Posted by: Greg | Date: 2023-03-24 17:22 | IP: IP Logged
I modified this line :
mCopyFullFileName_Caption=Copier le chemin complet vers le presse-papiers
I just put a letter m : "comlet" doesn't mean anything.
Posted by: pspad | Date: 2023-03-24 17:52 | IP: IP Logged
Greg:I wanted to put formatted text on MS Word but when i paste it's not the entire line with background color but just the word's background color.
Fixed, in the next build
