You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (765) English
Goto Page: Previous1 2
#11 Re: PSPad unicode 5.0.7 (765) English
Posted by: Gabriel_ACE | Date: 2023-03-23 14:48 | IP: IP Logged
Gabriel_ACE:
Is there a possibility that you add to the program the possibility of adding custom buttons on the bar?
I need to add a button to the bar that allows me to press it and for the program to open a file inside it
as a shortcut
as a programmer I have a lot of information in a text file but I don't want to have hundreds of tabs open in the program
What about to use Favourite tab and put your files there?
I used it for my TXT files and it works quite well
Excelent! I will Do thats! THZ!
