You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (757) English
Posted by: pspad | Date: 2023-02-15 11:02 | IP: IP Logged
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting yet.
SHA1 hash:
7208daacf7eb651d3aa0d894d65640d61d7b3d4d pspad507b757.zip
d1e597b7684d7ac07134e20ccf27ac83dda3e242 pspad507b757x64.zip
Changes to 5.0.7 (751)
News:
Program settings / Colors - Current tab changes top highlight color of the current file tab
Program settings / Direct edit - HighlughtCurrentFileTab=0 switches off top highlight of the current file tab
HTML highlighter highlights new pairs FIELDSET, LEGEND
OpenSSL libraries updated to 3.0.8 version
Removed:
Set PSPad as IE source viewer
User convertor added additional line to the line end if no text was selected
Problem with open big file and NO answer
Group UNDO problem
Other fixes reported by users
Posted by: Freeman | Date: 2023-02-17 04:12 | IP: IP Logged
Thank you for the update.
I'm sorry, but current tab highlighting still unusable for me. Now it's white while in the release version it uses a color from the system, looks ~50% gray on my system theme (still Windows 7). Highlighting color setting affects only the thin line on the tab top.
I've also found two bugs in translation:
• Missing bCurrentTab_Hint (?), I see 'Barva, která částečně ovlivňuje zvýraznění závorek'
• /n instead of \n in rs_CompError
Posted by: pspad | Date: 2023-02-17 06:27 | IP: IP Logged
OK, you still can set top line color to less intrusive than default orange and let HighlightcurrentFileTab=1
