You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (751) English
Posted by: pspad | Date: 2023-01-08 18:47 | IP: IP Logged
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting yet.
SHA1 hash:
df53f36c6f78fa42997627661295c5ba1d223ed7 pspad507b751.zip
c19f99b0704576d5723ff048fd4ff9eb749dea33 pspad507b751x64.zip
Changes to 5.0.7 (747)
News:
JavaScript Code explorer - added CLASS support
G-Code user highlighter definition (Arman Hayots)
Removed:
RSS highlighter, cause it duplicates XML highlighter
User highlighter - keywords start with option fixed for negative numbers e.t.c.
Code pages settings - arrows doesn't stay on the bottom when window was resized
Other fixes reported by users
Posted by: Freeman | Date: 2023-02-03 08:37 | IP: IP Logged
I haven't found in which beta you've changed color of active tab to orange, Notepad++ style. I'm sorry, but it's very annoying for me. Could you please revert it to gray or add a setting to allow users to choose a comfortable color?
Posted by: pspad | Date: 2023-02-03 08:53 | IP: IP Logged
What do you prefer? possibility to switch off highlighting of current tab or possibility to choose color?
Posted by: MicCo | Date: 2023-02-03 08:56 | IP: IP Logged
Hi
I´ll choose the color option.
Best regards,
MicCo
(I'm the translator of the Danish language file, if You find any error, please contact me.)
The file can be downloaded @ www.micco.dk
Posted by: Freeman | Date: 2023-02-03 08:59 | IP: IP Logged
pspad:What do you prefer? possibility to switch off highlighting of current tab or possibility to choose color?
Both.
Posted by: PGomersall | Date: 2023-02-10 16:58 | IP: IP Logged
Jan,
Just wondering if you have any plans for removing or changing (to new browser) "Register in IE as HTML viewer" given that IE is effectively dead?
Pete
Posted by: pspad | Date: 2023-02-10 18:55 | IP: IP Logged
I can remove this option. PSpad now supports IE and Edge as engine (WebView runtime is required for edge). Edge still supports IE engine for webs you want, even IE GUI was removed in W11
Posted by: PGomersall | Date: 2023-02-12 15:14 | IP: IP Logged
Jan if the feature still has functionality leave it, but maybe update the label text to better describe it?
Pete
Posted by: Piotr | Date: 2023-02-13 08:14 | IP: IP Logged
I have no application color choice: prnt.sc
I overwritten the files 3 times
Thank you for a great programme
Posted by: pspad | Date: 2023-02-13 08:47 | IP: IP Logged
Piotr:Hi,I have no application color choice: prnt.sc
I overwritten the files 3 timesThank you for a great programme
Schemes caused problem with stability. This is a reason, why schemes temporary disabled
