You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (745) English
Posted by: pspad | Date: 2022-12-04 20:38 | IP: IP Logged
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting yet.
SHA1 hash:
6dc081b8726d39f4bfffa803a995df9bca70cb07 pspad507b745.zip
ca7facf8d67ae08d854f2a6b383aedec3d5ac2db pspad507b745x64.zip
Changes to 5.0.7 (741)
News:
File tab context menu now contain 2 items for copy file name and file name including path
User Highlighter keyword lists extended of indication "Start with". If definition is followed by numbers, keyword is highlighted.
Recent storage is saved on program close
TextDiff with running PSpad and registry integration to the Windows explorer context menu
Search/Replace - load profile trims quotes from expressions
Switch to HEX mode and back mark file as modified
Ruby strings %/.../
When SpellCeck was active, it doesn't work for new open files in some cases
Fixed many problems in 64b build
Other fixes reported by users
Posted by: TomasV | Date: 2022-12-05 18:27 | IP: IP Logged
Thanks for all the updates, there's a minor issue with the latest one.
When I open PSPad and it automatically restores my last opened files, the highlighter is set to C++ for all those files. TXT, Python, Windows batch files all set to C++. If I open those files manually, the highlighter is set correctly based on their extension, so it must be something with the the initial opening after the restart.
Thanks!
Posted by: pspad | Date: 2022-12-06 05:33 | IP: IP Logged
You are right. It's really strange.
Posted by: pspad | Date: 2022-12-06 08:02 | IP: IP Logged
Problem found
As temporary workarround till next build you can disable "save file state" option in the program settings / Files and dirs
Posted by: TomasV | Date: 2022-12-06 14:06 | IP: IP Logged
Fantastic, thank you!
