You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (727) English
Posted by: pspad | Date: 2022-01-11 13:42 | IP: IP Logged
SHA1 hash:
52d079a43ae5833300af24e42b9522d954ecb656 pspad507b727.zip
3a8dfe6f59231fd37755ad4a81e8a08ce286e982 pspad507b727x64.zip
Changes to 5.0.7 (723)
File explorer - fixed form resize or show/hide log behavior
Search/replace recent strings was trimmed of initial spaces
Reload file in split window
Other fixes reported by users
Edited 1 time(s). Last edit at 2022-01-13 18:56 by pspad.
Posted by: LouCypher | Date: 2022-01-16 07:36 | IP: IP Logged
I don't know if this is the right place for a feature request but since it isn't a bug I'm adding it here:
Windows 11 has introduced a new file context menue (right click on a file in file explorer). The old context menue with the PSPad entries is available in a second level "Show more options". Some applications on my system has already been adapted to Windows 11 and are able to display their file context menue entries on the first level of the Windows 11 context menue. It would be very handy to adapt the PSPad file context menue extension correspondingly to Windows 11.
Posted by: pspad | Date: 2022-01-16 08:01 | IP: IP Logged
I am using Windows 11, but I didn't met any application what add entry into Windows 11 first level menu, except applications what are part of the Windows 11 or wrote by Microsoft. Can you give me some 3rd party application what has entry in the W11 context menu?
Posted by: LouCypher | Date: 2022-01-16 08:31 | IP: IP Logged
Posted by: PGomersall | Date: 2022-01-16 23:38 | IP: IP Logged
Jan,
Maybe this blog may help: blogs.windows.com
Pete
Posted by: pspad | Date: 2022-01-17 05:52 | IP: IP Logged
PGomersall:
I found this one 2 days ago. But I need to study it and write new shell extension.
Posted by: Ravelli | Date: 2022-03-21 17:56 | IP: IP Logged
Autocomplete Gets Confused By Typing Speed
When I create a new PHP file and type "mysqli" in one go(quickly), then the Autocomplete window suggests me maybe 30 different strings beginning with "mysqli". That's ok! But when I type "mysql" only, then wait for the Autocomplete window appearing, and then type the "i", the Autocomplete window suggests me 2 strings only: Screenshot. My Autocomplete delay is set to 500 ms.
Friendly greetings!
Posted by: Ravelli | Date: 2022-03-21 18:13 | IP: IP Logged
Found another issue:
Autocomplete Gets Confused On Typo Correction
When I type "mysqlo" into a PHP file, the Autocompelte window does not appear, because there is no string beginning with "mysqlo". If I then use backspace to delete the "o", the Autocomplete window vanishes, which is bad. If I then type in the correct letter "i", the Autocomplete window appears again. This must be related to the Autocomplete delay, which I have set to 500 ms. Because, when I type fast and remove the o instantly, then the Autocomplete window appears properly. As if the delay surpresses the Autocomplete window.
