You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (721) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 5.0.7 (721) English
Posted by: pspad | Date: 2021-12-19 16:00 | IP: IP Logged
SHA1 hash:
229ad2759fd0c47ee6bd83a5c52be01470404170 pspad507b721.zip
63f0ccb27232291c0f9910a233a7fa0edca0e7e1 pspad507b721x64.zip
Changes to 5.0.7 (717)
News:
Modified lines indication
Copy formated text - new function in the Edit menu or editor context menu allows you copy highlighted text into richtext format editor, e.g. Word
Windows shell script highlighter
Parameter /F doesn't start from the begin but from cursor position
Restore files doesn't restore last active file tab
Other fixes reported by users
#2 Re: PSPad unicode 5.0.7 (721) English
Posted by: Gabriel_ACE | Date: 2021-12-21 16:26 | IP: IP Logged
Excelent work!!!
but I found a bug
when you move cursor using arrow to left or right the vertical line dont' move
when you are in a part of the document that's not have string, but the cursor does
any way
Can you add an option that block vertical selection? becaus when I copy from another place (like terminal emulator), I need to paste in pspad many times in the same formart
but when I paste selection in pspad always return to defalt selection mode
Best Regards
#3 Re: PSPad unicode 5.0.7 (721) English
Posted by: pspad | Date: 2021-12-21 18:12 | IP: IP Logged
It's already fixed, wait for the next build.
According to block style selection. In program settings / Editor 1 switch off option:
Alt sets column mode
This will switch off return to normal by clicking mouse
#4 Re: PSPad unicode 5.0.7 (721) English
Posted by: Gabriel_ACE | Date: 2021-12-21 18:16 | IP: IP Logged
THK!!!!!!!!!!! grinning smileygrinning smileygrinning smileygrinning smileygrinning smileygrinning smileygrinning smileygrinning smileygrinning smiley
#5 Re: PSPad unicode 5.0.7 (721) English
Posted by: Lolo Irie | Date: 2021-12-22 10:27 | IP: IP Logged
Juste want to write here.........
I love the "Modified lines indication" feature. Well done (one more time) !!!
#6 Re: PSPad unicode 5.0.7 (721) English
Posted by: Gabriel_ACE | Date: 2021-12-22 17:54 | IP: IP Logged
I would like to make one more request
I would like the highlighter for cobol to have the ability to collapse the code between "performs"
I would also like that for the "if", "evaluate", etc.
for example all reserver word like if, evaluate, perform end with END-IF, END-EVALUATE
END-PERFORM
IF variable = variable 2
do stuff
ELSE
do other stuff
END-IF
same for
EVALUATE variable
when 10
do stuff
when 1000
do stuff
END-EVALUATE
perform is like FOR or WHILE
PERFORM varying i from 1 by 1
until i > 100
do stuff
END-PERFORM
PERFORM
until variable = "end"
do stuff
END-PERFORM
STRING ......
END-STRING
ACCEPT
END-ACCEPT
WRITE
END-WRITE
EXEC
END-EXEC
READ
END-READ
ALL USE END-... to end the sentence
can you do that? pleeeeeeaaaaaase winking smileywinking smileywinking smileywinking smileywinking smileywinking smiley
#7 Re: PSPad unicode 5.0.7 (721) English
Posted by: pspad | Date: 2021-12-22 18:09 | IP: IP Logged
Yes, I can add it.
I need more complex code source example. Can you send me some?
And as I looked into my samples library, I can't add contruction like PERFORM e.t.c. what can be without END-PERFORM, cause it breaks code folding.
So I need list of commands, where end of command is mandatory, like IF END-IF
Edited 1 time(s). Last edit at 2021-12-22 19:06 by pspad.
#8 Re: PSPad unicode 5.0.7 (721) English
Posted by: Gabriel_ACE | Date: 2021-12-22 23:14 | IP: IP Logged
ok this is the complete list of reserver word that can uses thas feature
do stuff
ELSE
do other stuff
END-IF
same for
EVALUATE variable
when 10
do stuff
when 1000
do stuff
END-EVALUATE
ADD variable to variable2 end-add
call "program" using variable returning variable2 END-CALL
COMPUTE variable = 2 + 2 END-COMPUTE
DELETE file
ON INVALID KEY
what to do
NOT ON INVALID KEY
what to do
END-DELETE
DIVIDE variable into variable2 GIVING variable3 END-DIVIDE
INVOKE "ssssss" using variable returning variable2 END-INVOKE
MULTIPLY variable by variable2 end-multiply
READ file
at end
what to do
not at end
what to do
END-READ
SEARCH variable
at end
do stuff
when variable(indice-index) = "hi!!"
do stuff
END-search
WRITE file from variable
END-WRITE
REWRITE file from variable
END-REWRITE
start file key not less variable
END-START
STRING "HI" delimited by sice
"I AM GABRIEL" delimited by sice
END-STRING
ACCEPT variable from promt
END-ACCEPT
SUBTRACT variable from variable2 END-SUBTRACT
UNSTRING variable delimited by "-"
into variable2
into variable3
end-UNSTRING
EXEC CICS
do STUFF
END-EXEC
EXEC SQL
SELECT column1
INTO variable1
from table
where a= 3
END-EXEC
until i > 100
do stuff
END-PERFORM
PERFORM
do stuff
END-PERFORM
THIS IS ALL
I use this link to find all sintax example
RESERVER WORD
www.ibm.com
SINTAXIS RESERVER WORDS
www.ibm.com
if you need something more tell me!! grinning smiley
#9 Re: PSPad unicode 5.0.7 (721) English
Posted by: pspad | Date: 2021-12-23 05:59 | IP: IP Logged
Yes, but some construction doesn't need mandatory END. Something like:
IF something
PERFORM something
END-IF
This construction break code folding, because I am not able recognize end
And such constructions can be more, not PERFORM only
#10 Re: PSPad unicode 5.0.7 (721) English
Posted by: Gabriel_ACE | Date: 2021-12-23 11:01 | IP: IP Logged
You are mistaken.
everyone needs the "END"
what happens is that in "COBOL"
you can close an instruction with a period
for example
IF variabe = 10
do stufff .
or
evaluate variable
when "HI"
do STUFF .
it is a specific property of cobol to be able to end any sentence with a period
but it is not the idea since it tends to cause programming errors
for example you can pass the following error
FINE:
IF variable = 100
DISPLAY "HELLO WORD"
DISPLAY "MERRY CRISMAS"
END-IF
NOT FINE:
IF variable = 100
DISPLAY "HELLO WORD" .
in the first example display only work when variable = 100
IF NOT the result is empty
and the second example if variable not = 100
the result display is "MERRY CRISMAS" because the "." close sentence before thats display
it is a common mistake
because old programmers are used to using "." at the end of each sentence
thing that is not necessary
the best way is always using END-XXX in all structure
