You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (721) English
Goto Page: Previous1 2 3 Next
#11 Re: PSPad unicode 5.0.7 (721) English
Posted by: pspad | Date: 2021-12-23 11:14 | IP: IP Logged
I though it too, that there must be a point, but in samples I have there is many cases where there is no END- not point on the end.
Examples:
There is IF without END-IF, MOVE without END-MOVE, but there are dots. BUT. The dot ends MOVE and IF together.
IF WS-XXX-YYY = 1
MOVE 'SSR' TO FXXXX-ID.
MOVE '/' TO FXXXX-S1.
MOVE WS-CCCC-SSS TO FXXXX-IN.
Second example - there is IF - END-IF, but few MOVE without dots
IF NOT CHECK-CODE
MOVE "ge05cdar not installed!!" TO MSG-WXX
MOVE SPACES TO MSG-WXX MSG-WYY
MOVE "Attention" TO MSG-TXX
PERFORM MSG-WXX
END-IF
Both cases withh break code folding
#12 Re: PSPad unicode 5.0.7 (721) English
Posted by: Gabriel_ACE | Date: 2021-12-27 12:06 | IP: IP Logged
I understand you.
the rule is simple
the "." has priority over END-XXXX
many programmers use points just to save typing
if you try to compile the following example the compiler will cancel
IF variable1 = 100
move "HI!!!" TO WS-VARIBLE2 .
END-IF
the compiler will detect an "END-IF" that is not associated with any "IF" and considers it an error
but you can do this too:
IF variable1 = 100
END-IF.
you can use at the same time
what I don't understand is the following:
in pspad when the mouse passes over an IF it always detects and remarks the END-IF correctly
Can't you use the same logic for this topic that I'm asking you?
taking into account what I'm telling you ...
Is it possible to make the change on the pspad?
#13 Re: PSPad unicode 5.0.7 (721) English
Posted by: pspad | Date: 2021-12-27 12:15 | IP: IP Logged
What about the forst case:
IF F01 PERFORM HELP SET SCS-RIPETI TO TRUE.
There is IF and PERFORM without END-IF or END-PERFORM with only one DOT.
Edited 1 time(s). Last edit at 2021-12-27 13:17 by pspad.
#14 Re: PSPad unicode 5.0.7 (721) English
Posted by: pspad | Date: 2021-12-27 14:25 | IP: IP Logged
I will make some first version. Check it and we can continue to modify it.
#15 Re: PSPad unicode 5.0.7 (721) English
Posted by: Gabriel_ACE | Date: 2021-12-27 14:33 | IP: IP Logged
I am going to transcribe it in a clearer way so that it is understood
IF F01 ---------> is a boolean variable (true or false)
PERFORM HELP
STOP RUN
HELP.
DO STUF
HELP-EXIT. EXIT.
F01 ----> boolean variable, if is true
then computer go perform HELP, do stuff, then RETURN and SET SCS-RIPETI TO TRUE
another way to write that sentences is:
IF F01
PERFORM HELP
END-IF
STOP RUN
HELP.
DO STUF
HELP-EXIT. EXIT.
If you need more help or explanations, I am here for you
#16 Re: PSPad unicode 5.0.7 (721) English
Posted by: pspad | Date: 2021-12-27 14:38 | IP: IP Logged
You didn't understand me
There was IF and PERFORM on the one line and line ends with DOT.
It means DOT ends both commands and serves as substitution for missing END-PERFORM and END_IF. Right?
#17 Re: PSPad unicode 5.0.7 (721) English
Posted by: Gabriel_ACE | Date: 2021-12-27 15:43 | IP: IP Logged
it is not exactly like this:
all cobol instructions can be closed with a period
for example:
MOVE variable1 TO variable2
or
MOVE variable1 TO variable2.
is the same.
in the case of "perform" it has several nuances
I'm going to write you all
PERFORM 1000-start ----> computer jump to 1000-start do stuf and then return
PERFORM 1000-start ----> the same than before
thru 1000-start _|
PERFORM 1000-start ---> the same than before but loop until end of file
until EOF
thru 1000-start _|
UNTIL EOF
USING "." is the same
PERFORM 1000-start. ----> compute jump to 1000-start do stuf and then return
thru 1000-start. _|
PERFORM 1000-start. ---> the same than before but loop until end of file
until EOF
thru 1000-start. _|
UNTIL EOF
USING "END-PERFORM" is a special case
The "perform" is used to jump to another part of the code, do what is there and then return
but if you only want to use it as a for loop, that is where the END-PERFORM is used
PERFORM varying I from 1 by 1
until I > 10
DISPLAY I
END-PERFORM
OR
until I > 10
DISPLAY I . ----> see the dot... close the PERFORM
1000-start.
DO STUFF
1000-start-exit. Exit
Is this explanation useful? or did I understand wrong?
#18 Re: PSPad unicode 5.0.7 (721) English
Posted by: pspad | Date: 2021-12-27 15:47 | IP: IP Logged
hello
yes, it's usefull, but I am not able to count with all possible cases in code folding especially when cases can be nested.
Try build 723, but I am afraid it's near all what I can do.
#19 Re: PSPad unicode 5.0.7 (721) English
Posted by: Gabriel_ACE | Date: 2021-12-27 17:53 | IP: IP Logged
hello
I already tried the IF, evaluate
and the perform y seem to work correctly
even ending the syntax with period
Excellent job! grinning smiley
#20 Re: PSPad unicode 5.0.7 (721) English
Posted by: pspad | Date: 2021-12-27 18:01 | IP: IP Logged
There can be situation what will fold incorrectly, but till the end of section only.
