You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (710) English
#1 PSPad unicode 5.0.7 (710) English
Posted by: pspad | Date: 2021-11-19 11:46 | IP: IP Logged
Download links:
SHA1 hash:
9f9a355506545f61efd975bafa5ac126fcac0535 pspad507b710.zip
d4647bbe90d5813714313ca57aecd6a9edcf8c5d pspad507b710x64.zip
Changes to 5.0.7 (705)
News:
Compiled in current Delphi version but temporary without skin support
Editor component - reworked UNOD/REDO - report problems please
TextDiff - fixed Window redraw when switching tabs
TextDiff - fixed Ctrl+Mouse wheel behavior
TextDiff - fixed unwanted block selection after dblclick
Reopen modified file
SpellCheck - fix for cyrilic languages, improved similar words search
In some cases closed file wasn't written into recent files list
Other fixes reported by users
#2 Re: PSPad unicode 5.0.7 (710) English
Posted by: TomasV | Date: 2021-11-24 11:09 | IP: IP Logged
Hi, it looks like Ctrl+Backspace has stopped working recently. It only deletes the last word, but then stops if there is a space before the cursor. Thanks
#3 Re: PSPad unicode 5.0.7 (710) English
Posted by: pspad | Date: 2021-11-24 11:42 | IP: IP Logged
Thank you for report. I will try to find a reason.
#4 Re: PSPad unicode 5.0.7 (710) English
Posted by: pspad | Date: 2021-11-24 19:33 | IP: IP Logged
TomasV:
Fixed, available in the next build.
Fix was send into Synedit project on the GitHub as well.
#5 Re: PSPad unicode 5.0.7 (710) English
Posted by: Vany | Date: 2021-11-25 08:29 | IP: IP Logged
CTRL+DEL doesn't work as well
(PSPad 5.0.7 (705) x32, W10h/p x64 en/cs)
#6 Re: PSPad unicode 5.0.7 (710) English
Posted by: pspad | Date: 2021-11-25 14:23 | IP: IP Logged
Thank you, fixed too and pull request with changes has been sent to primary Synedit repository
