You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (701) English
Posted by: pspad | Date: 2021-11-03 17:48 | IP: IP Logged
Download links:
SHA1 hash:
c9242eab3b825f571da5a20d6b0e72486e3ace60 pspad507b701.zip
d9dd5d5684b7c43ff8304b1cca15d31390eb05a0 pspad507b701x64.zip
Changes to 5.0.7 (689)
Experimental version!!!
Because I suspect the compiler and changes in the implementation of working with windows in new versions of Delphi, I have prepared a version that is compiled in an older version. Please report any problems, I would welcome a comparison with the previous build 689
Posted by: Gabriel_ACE | Date: 2021-11-04 19:00 | IP: IP Logged
new spanish update (I used spanish.ini from this post)
Edited 1 time(s). Last edit at 2021-11-04 19:00 by Gabriel_ACE.
Posted by: marco.tiraferri | Date: 2021-11-05 13:30 | IP: IP Logged
Thanks for reply to my error dump .
This new version is missing the ctrl+mouse wheel zoom, i found it very nice.
Does it will come back?
Bye,
Marco
Posted by: pspad | Date: 2021-11-05 13:34 | IP: IP Logged
Yes of course it will be back.
I found another problems - opening files by clicking on it when dark theme is set.
It's caused by old Delphi version. I must step up one version.
