You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (681) English
Posted by: pspad | Date: 2021-08-15 18:14 | IP: IP Logged
Download links:
SHA1 hash:
4f1e653f6bedd09cbc1b53fc99f155675cbdac84 pspad507b681.zip
39d1516d729128d04b35946ff11b809bae278de6 pspad507b681x64.zip
Changes to 5.0.7 (675)
News:
New Delphi 11 compiler with default memory manager - test
Ruller content after program start
Code clips activation after file load
Other fixes reported by users
Known issues:
Edited 1 time(s). Last edit at 2021-08-16 16:55 by pspad.
Posted by: MadCompie | Date: 2021-08-25 12:52 | IP: IP Logged
Yet again application error with this version.
There were 8 open files (opened via FTP).
I guess the error happened after closing a file:
List index out of bounds (230)
Exception class: EStringListError
Exception address:
Stack list, generated 25/08/2021 14:48:30
Thank you for the report, but please
send such logs to Jan's mail address found in PSPad > Help > About
Program : C:\<myuser>\PSPad editor\PSPad.exe 5.0.7 (681)
System : Windows 10 Professional x64, Version: 10.0, Build: 47BB,
Processor: Intel, Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz, 2300 MHz MMX
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit ""
Edited 1 time(s). Last edit at 2021-09-09 11:48 by Stefan.
Posted by: MadCompie | Date: 2021-08-25 13:09 | IP: IP Logged
Apparently, I saw that my file Recent.ini contained in the middle some binary chars in the [script] tag. After I removed these chars, PSPad acted normally again... Perhaps this is the problem?
Posted by: MadCompie | Date: 2021-08-26 08:07 | IP: IP Logged
Some other strange char phenomenon.
I open some files via FTP, it happens sometimes that 1 file contains Chinese chars in the tab's tooltip. The name in the tab is correct.
But when saving the file, an error occurs "connection: ...chinese chars".
Then I close this file and after reopen all is OK...
Posted by: Ravelli | Date: 2021-08-30 18:55 | IP: IP Logged
Hello everybody,
with this version I get occasional crashes due to access violation. Unfortunately I can not send the log, because the window 'application error' can not be reached. There is a smaller window in front of it, with an OK button. Hitting this a couple of times will not help getting rid of it. So, I have to close PSPad via task manager. All I can show you is this screenshot: snipboard.io
This access violation happened when I double-clicked a PHP in my file-explorer (FreeCommander XE) to open it - a file I had not touched for three days.
Friendly greetings
Ravelli
Posted by: ramoncar | Date: 2021-09-06 07:20 | IP: IP Logged
I also find chars in the text editor screen that are not really in the original file.
Maybe a problem in the file loader ?
Kind regards
Posted by: ramoncar | Date: 2021-09-06 07:22 | IP: IP Logged
Please find below the stack dump that appeared when I clicked on the document (not sure exactly if left or right click)
There were two tabs with the same file name (from different folders)
After the first time, it appears repeatedly every time I single left click on any part of the document.
Kind regards
Exception description:
Exception address:
Stack list, generated 06/09/2021 09:14:28
Program : C:\PROGRA~1\PSPADE~1\PSPad.exe 5.0.7 (681)
System : Windows 10 Professional x64, Version: 10.0, Build: 3FAB,
Processor: Intel, Intel(R) Core(TM) i5-4310M CPU @ 2.70GHz, 2690 MHz MMX
Skin : Windows
TPSSynEdit ""
TfChildEdit ""
Edited 2 time(s). Last edit at 2021-09-09 11:46 by Stefan.
Posted by: Stefan | Date: 2021-09-09 11:44 | IP: IP Logged
Hi Jan,
thank you very much for the updates.
Unfortunately I have found a misbehavior:
Cannot open file "...current path..\PSPad.ini".
Exception class: EFOpenError
I had just unpacked the last developer build into a new folder.
I know this is just an update to overwrite our older files with,
but me think such basic as creating an new PSPad.ini if not found
should not stop the app from launching and instead crashing.
I would like to suggest to create just a new, fresh ini if not found
in the same folder as the exe is and as it was with older builds too.
Copying my old PSPad.ini or just
creating an new textfile named PSPad.ini solve this problem for me.
Posted by: ramoncar | Date: 2021-09-11 09:50 | IP: IP Logged
Thanks Jan,
I didn't knew were to send the report, the Mail button in the error dialog does not work for me, it tries to open the email client, but I always use web mail, my email application is not configured.
Hint: include the email address in the "Copy to Clipboard" data. This may help other people in the same situation.
Kindest regards
Posted by: pspad | Date: 2021-09-11 13:59 | IP: IP Logged
In the about program dialog is e-mail, on the pspad web is e-mail. I will put e-mail address into exception dialog too.
