You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (669) English
Posted by: pspad | Date: 2021-07-16 13:48 | IP: IP Logged
Download links:
SHA1 hash:
efdc5584bd91982904ecb7d958ea06dde54cbcf2 pspad507b669.zip
deba22878036993ebb58398df142df55c5d709c4 pspad507b669x64.zip
Changes to 5.0.7 (665)
News:
When Save file state is enabled, user changed highlighter has priority over HTML multihighlighter.E.g. PHP file is open in HTML multihighlighter, user changes highlighter to PHP. Next time PSpad will open file as PHP, not as HTML multihighlighter
UserHighlighter - some keywords wasn't highlighted
Call 2x Clear history in Program settings / Files
After Find/Replace save icon wasn't highlighted
Active tab after open file from left panel
Other fixes reported by users
Known issues:
Posted by: fyurisich | Date: 2021-07-19 00:56 | IP: IP Logged
After adding an entry to my highlighter definition file the whole functionality stop working and my .ini files were trashed.
The first lines:
APIENTRY=
BOOL=
BYTE=
The last lines:
[KeyWords2]
[KeyWords3]
[KeyWords]
[ReservedWords]
[Settings]
_INCLUDE_OOHG_MENU_CONSTANTS_=
_TEXT=
_WIN32_IE=
_WIN32_WINNT=
_WIN64=
__HARBOUR__=
It's like all the lines, including the tags, were sorted at the same time instead of sorting them per tag.
Thanks for you attention
Fernando
Posted by: pspad | Date: 2021-07-19 07:27 | IP: IP Logged
Thank you for report of this very serious bug. I will fix it as soon as possible.
