You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (663) English
Posted by: pspad | Date: 2021-07-05 14:33 | IP: IP Logged
Download links:
SHA1 hash:
220a26573754b131ea8e815a785804a76e8daef3 pspad507b663.zip
e97cdd5e47252625cca16f1f247f41d1354d208c pspad507b663x64.zip
Changes to 5.0.7 (659)
News:
In splitted window bookmarks are synchronized
FileTabs visibility when you close all files and open several files using OpenDialog
Windows shell script - variable %~xx highlighting
Paste the copied text into Excel
Autorefresh symbol on file tab
Other fixes reported by users
Known issues:
Posted by: Ilya | Date: 2021-07-06 04:56 | IP: IP Logged
In this version, when you try to open (using File-Open) an already open file, its tab does not become active.
If you use the Windows context menu, the tab becomes active.
I don't remember if I saw this behavior in a previous version, but 638 works as expected.
Posted by: gwinkless | Date: 2021-07-06 09:02 | IP: IP Logged
Ilya:In this version, when you try to open (using File-Open) an already open file, its tab does not become active.
Possibly related: double-clicking on a result in the search-in-files-results window no longer opens the result file, it just takes you to the line number of the search result in the current editor window.
That's a blocker for me. Going back a version
Edited 1 time(s). Last edit at 2021-07-06 09:03 by gwinkless.
Posted by: pspad | Date: 2021-07-06 09:06 | IP: IP Logged
I will try to fix it as soon as possible
Posted by: pspad | Date: 2021-07-07 16:26 | IP: IP Logged
Fixed in 665
Posted by: Ilya | Date: 2021-07-08 04:49 | IP: IP Logged
pspad:Ilya:In this version, when you try to open (using File-Open) an already open file, its tab does not become active.
I don't remember if I saw this behavior in a previous version, but 638 works as expected.Fixed in 665
Confirmed.
