You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (651) English
#1 PSPad unicode 5.0.7 (651) English
Posted by: pspad | Date: 2021-06-11 18:56 | IP: IP Logged
Download links:
SHA1 hash:
2031c052fd86112ce43ef39ef3a986794bc921e0 pspad507b651.zip
64cdf2c1a7a3802232efdcabd70db0fe8d327073 pspad507b651x64.zip
Changes to 5.0.7 (649)
News:
Code folding can't be used together with Wordwrap. Wordwrap activating will disable Code folding for current file. Wordwrap deactivating will enable Code folding back (if supported for this file)
Closing of nonactive window using mouse on FileTab - focus in editor
if file is locked by another process, binnary file test raised exception
TextDiff window artefacts after splitter move
Search/Replace or Reload doesn't refresh symbol on the file tab
Copy/Paste in text without highlighter
Undo/Redo - assigning shortcut directly to editor command instead of application action when no Undo/Redo was available caused editor freeze
Other fixes reported by users
Known issues:
#2 Add/Remove Comment
Posted by: Greg | Date: 2021-06-12 22:37 | IP: IP Logged
First, thank you for Code folding and Wordwrap. it works and it's intuitve.
I've seen a bug for a while now... When i select code finishing with a parenthesis and use "Add/Remove Comment" the parenthesis is not in comment.
Edited 2 time(s). Last edit at 2021-06-12 22:38 by Greg.
#3 Re: Add/Remove Comment
Posted by: pspad | Date: 2021-06-13 09:14 | IP: IP Logged
Confirmed. I will fix it.
#4 Re: Add/Remove Comment
Posted by: Professor Bernd | Date: 2021-06-13 13:50 | IP: IP Logged
Some keys in the KeyMap.INI are still created twice.
Maybe you could also take the opportunity to change the case of the file extension ".INI" to lowercase ".ini" for all newly created .ini files? smiling smiley
#5 Re: Add/Remove Comment
Posted by: Ravelli | Date: 2021-06-15 13:09 | IP: IP Logged
I double clicked a CSS file to open it, then I got this:
#6 Re: Add/Remove Comment
Posted by: pspad | Date: 2021-06-16 04:01 | IP: IP Logged
Ravelli:
When you close your file and open it again, was it present there or not?
