You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (643) English
Posted by: pspad | Date: 2021-05-29 16:36 | IP: IP Logged
Download links:
SHA1 hash:
252c79fb71f0769a9e185c13737efdd4f2e70139 pspad507b643.zip
9be8e0c3d30118ecc8ffa8522a065f81bda0defe pspad507b643x64.zip
Changes to 5.0.7 (638)
News:
PSPad is able to open file with broken UTF-8 encoding. After warning and confirmation.
Code folding - settings is part of the Program settings under editor
HEX edit - added history into Find/Replace
Ruby user highlighter - improved strings highlighting
Rewriten statusbar handling information, cleaned-up code from state, when statusbar was part of each window
PHP highlighter - highlight matching bracket in case of multiline string
File plugin fix
Another fixes reported by users
Known issues:
Posted by: bluezero | Date: 2021-05-30 05:31 | IP: IP Logged
Only the fosshub download link is working. The other two 404.
Other know issue is missing autoindend after running macro.
Posted by: pspad | Date: 2021-05-30 06:40 | IP: IP Logged
I tested autoindent after running macro, but I wasnt able to simulate it.
I wrote it to your add.
Can you provide any example?
Server is maybe under maintenance. This is a reason, why download is available from 2 locations
Posted by: Ravelli | Date: 2021-05-30 11:20 | IP: IP Logged
I just updated automatically to 643 and then opened a project file. In the toolbar there is now a folder named 'ad??n' instead of 'admin'. When I resync the project, the folder gets named 'admin' again.
Posted by: pspad | Date: 2021-05-30 12:08 | IP: IP Logged
It looks like corrupted project file. Can you please send me report file if it happen again?
Posted by: bluezero | Date: 2021-05-30 14:26 | IP: IP Logged
pspad:I tested autoindent after running macro, but I wasnt able to simulate it.
I wrote it to your add.Can you provide any example?
I posted the example in previous version:
forum.pspad.com
You should have the macro in one of the mails i sent you, but if you need it, then i will send it to you again.
Posted by: pspad | Date: 2021-05-30 14:46 | IP: IP Logged
I recorded it acording to example.
Can you try record new macro? Mayby editor behavior was changed
Posted by: bluezero | Date: 2021-05-30 15:21 | IP: IP Logged
The macro itself does not include the autoindending (ecTab).
That would not make sense, because its not always just one tab, its 2 or 3 or 4...
Therefore the autoindend must happen automatically after ecLineBreak, like it did in previous versions.
This is an example what happens when i record it with one tab, but try to start in on 2 tabs:
While testing that i noticed a different bug:
It reassigned the shortcut from my old macro to the new one.
Edited 1 time(s). Last edit at 2021-05-30 15:22 by bluezero.
Posted by: pspad | Date: 2021-05-31 06:11 | IP: IP Logged
OK. Do you have any "old" recorder macro? Can you record the same now and send me both macro files?
I need to find a difference.
Posted by: bluezero | Date: 2021-05-31 11:12 | IP: IP Logged
pspad:OK. Do you have any "old" recorder macro? Can you record the same now and send me both macro files?
Sent you the two macros by email.
The only difference is ecTab after line break.
