You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (638) English
Posted by: pspad | Date: 2021-05-23 11:33 | IP: IP Logged
Download links:
SHA1 hash:
07ec746e56d636af8709c3102d1362dbc2a70872 pspad507b638.zip
6dba092ab2128dd7e1e08d366d2c1843a6afbd5a pspad507b638x64.zip
Changes to 5.0.7 (629)
News:
Code folding manipulation is under the View menu, in the editor context menu, under toolbar button
Updated communication library Synapse
Implemented new OpenSSL version for FTP connection. Now libcrypto-1_1.dll and libssl-1_1.dll libraries are used (or their 64b versions) instead of the old libeay.dll and ssleay.dll what can be deleted.
HexEdit - Search/Replace witout confirmation doesn't mark file as modified
Split window, synchronize moving and unsplit window caused exception
Activation of last selected window after close current one
Ruby highlighter - embeded expression in string and other reported fixes
Save function is available always, tool button icon depends of the modified state
Macrorecording in empty files
Another fixes reported by users
Known issues:
Edited 2 time(s). Last edit at 2021-05-23 15:28 by pspad.
Posted by: bluezero | Date: 2021-05-24 13:06 | IP: IP Logged
There seems to be some bug in highlighting leading vs trailing bracket:
Cursor on leading bracket is red.
CTRL+M moves the cursor to the right trailing bracket and highlights both brackets with the right color:
Posted by: bluezero | Date: 2021-05-24 13:23 | IP: IP Logged
PSPad stops responding.
Without any error message, nor crash i have to close it with Task Manager.
File was PHP.
Multihighlighter.
i was about to write trailing comment marker "*/", but it stopped responding after the sign "*".
Posted by: bluezero | Date: 2021-05-24 13:28 | IP: IP Logged
This is reproduceable.
The key is to write the trailing comment marker "*/" first. If i did write the leading comment marker "/*" first and then the trailing, then it did not crash.
Posted by: pspad | Date: 2021-05-24 13:29 | IP: IP Logged
There are some problems with PHP highlighter.
Fix is available in the build 639
Regards your bracket problem, there must be something in code and without code I can't find a problem. Is possible to send me at least part of code to support mail?
Posted by: bluezero | Date: 2021-05-24 14:02 | IP: IP Logged
639 solved the "Not responding problem".
Sent you a sample file with the brackets problem per email.
Posted by: Ravelli | Date: 2021-05-24 14:53 | IP: IP Logged
In a PHP file, PSPad does not detect the closing bracket, when there is a line break in an echo statement:
Posted by: pspad | Date: 2021-05-24 16:46 | IP: IP Logged
Thank you guys for examples. Problem was found and fixed. It's joined with new editor component version
Posted by: Ravelli | Date: 2021-05-24 18:26 | IP: IP Logged
I wanted to add a comment to a PHP file, but as soon I hit SHIFT+7 to create a Slash /, PSPad stops working and closes.
It might be in my particular PHP file only, since it works fine in a new plain txt file - will investigate this a bit more later. It is a file, which hosts a collection of PHP functions, having about 780 lines. "HTML Multihighlighter" is in use, and code-page is "Unicode UTF-8 no BOM (65001)". It happens on line 9 as shown on this screenshot:
(Btw, the 'mixed' return type shown in the second function is'nt bold. I'm not sure, if this return type is already obsolete, but it compiles fine)
Posted by: pspad | Date: 2021-05-24 18:38 | IP: IP Logged
Few adds above your's is download link with fixed 639 build
