You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (623) English
Posted by: pspad | Date: 2021-05-05 11:08 | IP: IP Logged
I updated 623 yesterday due to updater problem.
I have confirmed from czech users that drag/drop works fine in this build.
Enough is replace pspad.exe only.
Posted by: bluezero | Date: 2021-05-05 11:17 | IP: IP Logged
Looks there is some memory leak in Codefolding:
The file extension is .php, contents are php + html.
I tried to disable multihiglighter, but that did not help, so i assume it is Codefolding.
Cant find a setting how to disable it, so i will have switch back to 620 (or 600 if it wont work).
Posted by: bluezero | Date: 2021-05-05 11:20 | IP: IP Logged
Update: 620 has the same problem. 600 can open the file.
Posted by: pspad | Date: 2021-05-05 12:06 | IP: IP Logged
1. You can disable codefolding in the program settings / Direct edit button
CodeFolding=0
2. Can you send me your file to support mail?
Posted by: bluezero | Date: 2021-05-05 12:30 | IP: IP Logged
Disabling the codefolding did not help.
I've sent the file to you by email.
Posted by: pspad | Date: 2021-05-05 12:54 | IP: IP Logged
Thank you for the file.
I can confirm, it end with out of memory message.
In my case after I close exception dialog, file was open in PSpad
Posted by: massimobalestra | Date: 2021-05-05 13:28 | IP: IP Logged
pspad:bluezero:Seems you changed the line numbers display to 1 .... 5 ... 10.
I did a quick search for a setting to change it back, but did not find it.
Can you please tell me where i can find the setting?It was test awaiting reactions. There is no settings yeat, cause I am not decided if i will let it there or not.
I think I like the new way, as it is now but I guess that an option would be appreciated.
Edited 1 time(s). Last edit at 2021-05-05 13:28 by massimobalestra.
Posted by: pspad | Date: 2021-05-05 13:40 | IP: IP Logged
Option will be available in the special settings.
I will make "old" way as default
Posted by: PGomersall | Date: 2021-05-05 14:59 | IP: IP Logged
Jan, updater seems to be fixed. I downloaded zip and updated updater then tested and verified operation.
I very much appreciate the code folding and the work you have put in to make it work. It would be nice to enable this as default on all curly bracket languages rather than having to set it. Maybe its useful to turn it on for all and see if it breaks anything while testing?
I also like the new line numbering format.
Version is showing 622 not 623?
Regards, Pete
Edited 1 time(s). Last edit at 2021-05-05 14:59 by PGomersall.
Posted by: pspad | Date: 2021-05-05 15:08 | IP: IP Logged
Problem is that there is 188 user highlighter definitions and I don't know what are "curly brackets" highlighters. Half of the languages I don't know.
I can go through of them, find sources on the net to see how source looks like and allow it. But it needs lot of the time.
If you (or anybody else) can write me list of user highlighters what uses curly brackets, I can allow it.
