You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (620) English
Posted by: bluezero | Date: 2021-05-04 06:12 | IP: IP Logged
Ok, will send it per mail next time.
It was a CSV and small, about 500 bytes.
Posted by: pspad | Date: 2021-05-04 07:19 | IP: IP Logged
What highlighter was used in your case?
CSV has no highlighter assigned
Posted by: bluezero | Date: 2021-05-04 16:40 | IP: IP Logged
This is selected by default when i open CSV file.
Same applies to the log i sent you by mail.
Posted by: pspad | Date: 2021-05-04 16:49 | IP: IP Logged
I tried to fix it in 623 build
Posted by: Professor Bernd | Date: 2021-05-04 18:06 | IP: IP Logged
pspad:Changes to 5.0.7 (600)News:
Updated editor component. Report please anything "strange".
Here you are.
I hope it helps.
Posted by: Professor Bernd | Date: 2021-05-05 03:44 | IP: IP Logged
I saw that and am very happy about it! I see many things that I'm happy about and I'm sure other users are too, for example the fixes in 5.0.7 (623) for Undo/Redo indicators, toolbar background color, and many more. I was especially happy to see this:
Code folding will enhance PSPad. It's a lot of work, I think. If there's anything I can do to help, I'd appreciate it. Maybe for AutoIt?
Posted by: Professor Bernd | Date: 2021-05-05 07:43 | IP: IP Logged
Posted by: pspad | Date: 2021-05-05 07:53 | IP: IP Logged
It's in case you keep shift, right?
When I make standard DBLclick, cursor is behind the word, at least in the 623 build.
Posted by: Professor Bernd | Date: 2021-05-05 08:20 | IP: IP Logged
The problem has expanded. Therefore I unpacked a fresh full version and unpacked the version 5.0.7 (623) to it. I am writing here so that the issue is not torn apart, but it affects version 5.0.7 (623).
pspad:It's in case you keep shift, right?
I did not press the shift key (nor any other), just double click with the mouse. The caret stays inside the selected word. And now I noticed that no dragging of selected text is possible. Maybe both things are related?
