You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (620) English
Posted by: pspad | Date: 2021-05-02 08:46 | IP: IP Logged
Download links:
SHA1 hash:
449bd70d96d160807e9d07fea0017dad592ed3f6 pspad507b620.zip
96a5fcd4cdfd4d456c3dc73a0e01964cf5077366 pspad507b620x64.zip
Changes to 5.0.7 (600)
News:
Updated editor component. Report please anything "strange".
CodeFolding support introduced - for now supported languages: JavaScript, Java, C#, C++, Perl, PHP, Pascal
CodeFolding support is possible to switch off in Program settings / Special settings: CodeFolding=0
Editor - tripple click select line, quadruple click whole text
Config backup - before each version update started from PSpad config files are automatically backed up into subfolder backup_cfg of config files placement.
Default limits (Program settings / Special settings) for Multihighlighter, Highlighting and Code explorer were increased to 750 000 bytes
SQL highlighter - added several SQL dialects (Nexus, Postgres, Informix)
Open more files at once from OpenDialog
Close numbered file tabs with mouse wheel doesn't update numbers
Remove nonexisting recent files when none recent files left
Drop binary file into TextDif box
Another fixes reported by users
Posted by: naputtelija | Date: 2021-05-02 09:38 | IP: IP Logged
pspad:CodeFolding support introduced - for now supported languages: JavaScript, Java, C#, C++, Perl, PHP, Pascal
Nice! Dou you have any plans to expand support some day to include PowerShell?
Posted by: pspad | Date: 2021-05-02 10:12 | IP: IP Logged
I did what I was able in time I had. There is necessary to add support into each highlighter, so I will roll up support for more highlighters.
Posted by: Professor Bernd | Date: 2021-05-03 12:29 | IP: IP Logged
Hello Jan.
I and I'm sure many other users really appreciate that you're working on the CodeFolding feature! That must be a lot of work, so here are just the most important bugs:
- Bug is back: highlighting of all occurrences is case sensitive.
- Toolbar has white background (in dark IDE style).
- Please disable undo/redo buttons if no undo/redo is available (as it was all the years before).
- When writing something and undoing it so there is nothing to save, sometimes all indicators stay as if there was a change to save. (Toolbar Save button is highlighted, asterisk in title bar, red triangle in tabs.) I could not reproduce the steps reliably, but surely other users can figure it out. It occurs mainly with files that belong to a PSPad project (.ppr).
- Button in Windows taskbar is moved to the end of the Windows taskbar every time a new tab is opened.
- If you apply "Close to right" on the last tab of a row and the next (last) row of tabs is closed, an empty row remains.
Thanks a lot for your work!
Bernd.
Posted by: pspad | Date: 2021-05-03 13:04 | IP: IP Logged
Thank you for feedback.
Highlight all occurences is my fault. There is new option in the program settings / Editor1: SelectOccurSensitive=0/1
But I forgot to set it in the settings dialog.
Open settings in direct edit and change it manually. At least one thing.
Posted by: pspad | Date: 2021-05-03 13:10 | IP: IP Logged
Undo/redo buttons are disabled when not available, but it doesn't looke like it.
Button is filled in with white color, I must check why.
Available button has yellow border
I found another bug in editor component. Fixed and reported.
Next uild will bring possibility to CodeFolding for user highlighter for curly bracket languages. Other user languages will be supported with "help lines" in code.
Edited 2 time(s). Last edit at 2021-05-03 16:46 by pspad.
Posted by: massimobalestra | Date: 2021-05-03 17:27 | IP: IP Logged
I really appreciate the code folder but I found a big difference in the last version.
The "Duplicate line" (ctrl+D for me) does not duplicate the current line (as before) but it duplicates something regarding on the column where the cursor is. I guess it duplicated from where the cursor is.
To replicate the old behavior I have to move the cursor at the beginning of the line, this is quite annoying for me.
How to go back to the old behavior: duplicate the current line regardless of what column the cursor is?
Thank you
Posted by: pspad | Date: 2021-05-03 17:59 | IP: IP Logged
massimobalestra:How to go back to the old behavior: duplicate the current line regardless of what column the cursor is?
Thank you
I must find change and fix it. Some behavior of the editor component is different and I am not able to test it whole alone.
Posted by: bluezero | Date: 2021-05-03 19:02 | IP: IP Logged
Closing file exception:
Exception description:
Access violation at address 00409718 in module 'PSPad.exe'. Read of address 8D004D1B.
Exception address: 00409718
Edited 1 time(s). Last edit at 2021-05-04 03:50 by pspad.
Posted by: pspad | Date: 2021-05-04 03:49 | IP: IP Logged
Plrase, don't send exception reports to forum but into support mail.
I need more information about file you closed - was it big file? File type?
