You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (598) English
Goto Page: Previous1 2
#11 Re: PSPad unicode 5.0.7 (598) English
Posted by: PGomersall | Date: 2021-04-23 02:29 | IP: IP Logged
Thanks Jan for addressing the update log logic.
Did you see my previous post about the position of the update dialog been centered on multi-displays i.e. can be in bad position?
Pete
#12 Re: PSPad unicode 5.0.7 (598) English
Posted by: pspad | Date: 2021-04-23 03:12 | IP: IP Logged
Yes, but you need to update updater itself. I need to find mechanism how to update updater.
#13 Re: PSPad unicode 5.0.7 (598) English
Posted by: PGomersall | Date: 2021-04-23 18:31 | IP: IP Logged
OK, the most recent version that I have is the one in the 598 zip update file; this (PSPUpdater.exe) was from 4/13/2021 which still opens in the middle of 2 display systems.
#14 Re: PSPad unicode 5.0.7 (598) English
Posted by: pspad | Date: 2021-04-23 18:41 | IP: IP Logged
Next version will open in screen center, will append log and will be able to update updater itself.
Wait fo weekend build please
#15 Re: PSPad unicode 5.0.7 (598) English
Posted by: maxshop | Date: 2021-04-24 15:18 | IP: IP Logged
Exception description:
Exception class:
Exception address:
Stack list, generated 4/23/2021 17:18:45
(See forum.pspad.com
or forum.pspad.com)
INFO
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thank you very much!
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.7 (598)
System : Windows 10 Professional x64, Version: 10.0, Build: 4A62,
Processor: Intel, Intel(R) Core(TM) i7-4600U CPU @ 2.10GHz, 2690 MHz MMX
Display : 1920x1080 pixels, 32 bpp PPI: 120
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 2 time(s). Last edit at 2021-04-27 09:53 by Stefan.
#16 Re: PSPad unicode 5.0.7 (598) English
Posted by: pspad | Date: 2021-04-25 08:13 | IP: IP Logged
maxshop:
Access violation at address 000000FF in module 'PSPad.exe'. Read of address 000000FF.
Exception address: 000000FF
Please send exception reports to support mail. Thank you.
If you use web mail interface or e-mail client without simple mapi support, there is still possibility to copy content to clipboard and paste into any mail in the PSPad excepiton dialog.
And please add sjort description what di you do when exception occured, e.g.: close file
In some cases I am not able recognize what caused exception.
#17 Re: PSPad unicode 5.0.7 (598) English
Posted by: Ravelli | Date: 2021-04-25 15:01 | IP: IP Logged
When performing double-click in file browser of tool bar onto a PHP file, I got a small window telling me "Text editor funktioniert nicht mehr". No access violation window appeared. I can only hit button "Programm schließen". which will close PSPad.
I had the same error and window appearing sometimes on previous versions.
I will switch later to the new dev version 600.
