You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (598) English
Goto Page: 1 2 Next
#1 PSPad unicode 5.0.7 (598) English
Posted by: pspad | Date: 2021-04-20 16:59 | IP: IP Logged
Download links:
SHA1 hash:
960ef9683d823f972c69033c935adf94a70527b1 pspad507b598.zip
c4f03eee2dae5f34ed0aa993ad040ce4b550e7ab pspad507b598x64.zip
Changes to 5.0.7 (597)
News:
SpellCheck dialog - for visually impaired people the label with original word was replaced for edit (readers support)
Memory manager was returned to default one
Autocomplete (Program settings / Editor 2) - New option Autocomplete replaces rest of the word. When Autocomplete is called from the middle of word it replaces/let the rest behind the cursor
Perl highlighter - q-function highlighting fix
Close file by mouse wheel doesn't redraw file tabs names
New project from folder - save button wasn't active
#2 Re: PSPad unicode 5.0.7 (598) English
Posted by: pspad | Date: 2021-04-20 17:00 | IP: IP Logged
Please report any exception regarding open or close file, same as any other exception.
DOn't forget to add description, I need to simulate problem to find a reason.
Thank you
#3 Re: PSPad unicode 5.0.7 (598) English
Posted by: PGomersall | Date: 2021-04-20 19:13 | IP: IP Logged
Jan,
Just one comment about the PSUpdater.exe UI, it opens center of total screen width, and if you have 2+ displays it can sit in bad place; it would probably be best to open center of default display?
Pete
#4 Re: PSPad unicode 5.0.7 (598) English
Posted by: PGomersall | Date: 2021-04-20 19:27 | IP: IP Logged
Secondly, the updater log, is it overwritten or appended to with each update? If appended, it would be useful to include the time stamp data.
I also setup ScheduledTask; this worked fine.
Pete
Edited 2 time(s). Last edit at 2021-04-20 19:28 by PGomersall.
#5 Re: PSPad unicode 5.0.7 (598) English
Posted by: pspad | Date: 2021-04-20 19:33 | IP: IP Logged
Updater log is written with unattended update only, cause in this case you don't see anything
#6 Re: PSPad unicode 5.0.7 (598) English
Posted by: PGomersall | Date: 2021-04-21 02:05 | IP: IP Logged
Yes, when run from commandline is log replaced or appended?
I ran task today and the output was no update available but with no timestamp data except from file modification.
If appended it would be useful to have date\time on output.
#7 Re: PSPad unicode 5.0.7 (598) English
Posted by: pspad | Date: 2021-04-21 02:08 | IP: IP Logged
Log is replaced.
I will change log behavior
#8 Re: PSPad unicode 5.0.7 (598) English
Posted by: pspad | Date: 2021-04-21 05:06 | IP: IP Logged
Unattended update will append entry to log. in the form:
----- 21.04.2021 7:03:47 ----
OK : PSPad editor EXE file found
OK : Check available PSpad version
OK : PSPad update download finished - full 5.0.6 (589) 32b
OK : Zip extracted to: C:\Users\Administrator\AppData\Local\Temp\pspadtemp
OK : Delete old backup folder
OK : Existing files backup
OK : Files update finished
OK : Temporary files clean up
----- 21.04.2021 7:04:17 ----
Info: You have already last full version.
#9 Re: PSPad unicode 5.0.7 (598) English
Posted by: bluezero | Date: 2021-04-22 16:21 | IP: IP Logged
Exception problem still present:
#10 Re: PSPad unicode 5.0.7 (598) English
Posted by: pspad | Date: 2021-04-22 16:39 | IP: IP Logged
I need exception report, no the pic of begin of it. Thank you
Goto Page: 1 2 Next
