You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (598) English
Posted by: pspad | Date: 2021-04-20 16:59 | IP: IP Logged
Download links:
SHA1 hash:
960ef9683d823f972c69033c935adf94a70527b1 pspad507b598.zip
c4f03eee2dae5f34ed0aa993ad040ce4b550e7ab pspad507b598x64.zip
Changes to 5.0.7 (597)
News:
SpellCheck dialog - for visually impaired people the label with original word was replaced for edit (readers support)
Memory manager was returned to default one
Autocomplete (Program settings / Editor 2) - New option Autocomplete replaces rest of the word. When Autocomplete is called from the middle of word it replaces/let the rest behind the cursor
Perl highlighter - q-function highlighting fix
Close file by mouse wheel doesn't redraw file tabs names
New project from folder - save button wasn't active
Posted by: pspad | Date: 2021-04-20 17:00 | IP: IP Logged
Please report any exception regarding open or close file, same as any other exception.
DOn't forget to add description, I need to simulate problem to find a reason.
Thank you
Posted by: PGomersall | Date: 2021-04-20 19:13 | IP: IP Logged
Jan,
Just one comment about the PSUpdater.exe UI, it opens center of total screen width, and if you have 2+ displays it can sit in bad place; it would probably be best to open center of default display?
Pete
Posted by: PGomersall | Date: 2021-04-20 19:27 | IP: IP Logged
Secondly, the updater log, is it overwritten or appended to with each update? If appended, it would be useful to include the time stamp data.
I also setup ScheduledTask; this worked fine.
Pete
Edited 2 time(s). Last edit at 2021-04-20 19:28 by PGomersall.
Posted by: pspad | Date: 2021-04-20 19:33 | IP: IP Logged
Updater log is written with unattended update only, cause in this case you don't see anything
Posted by: PGomersall | Date: 2021-04-21 02:05 | IP: IP Logged
Yes, when run from commandline is log replaced or appended?
I ran task today and the output was no update available but with no timestamp data except from file modification.
If appended it would be useful to have date\time on output.
Posted by: pspad | Date: 2021-04-21 02:08 | IP: IP Logged
Log is replaced.
I will change log behavior
Posted by: pspad | Date: 2021-04-21 05:06 | IP: IP Logged
Unattended update will append entry to log. in the form:
----- 21.04.2021 7:03:47 ----
OK : PSPad editor EXE file found
OK : Check available PSpad version
OK : PSPad update download finished - full 5.0.6 (589) 32b
OK : Zip extracted to: C:\Users\Administrator\AppData\Local\Temp\pspadtemp
OK : Delete old backup folder
OK : Existing files backup
OK : Files update finished
OK : Temporary files clean up
----- 21.04.2021 7:04:17 ----
Info: You have already last full version.
Posted by: bluezero | Date: 2021-04-22 16:21 | IP: IP Logged
Exception problem still present:
Posted by: pspad | Date: 2021-04-22 16:39 | IP: IP Logged
I need exception report, no the pic of begin of it. Thank you
