You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (597) English
Posted by: pspad | Date: 2021-04-18 10:11 | IP: IP Logged
Download links:
SHA1 hash:
067b20b8de830c8f489f449fbf90dc86f37854cc pspad507b597.zip
a9f7c59fb2afe7aaa24579798a380fd6c5749994 pspad507b597x64.zip
Changes to 5.0.7 (593)
News:
Color dialog - first 6 custom colors are remembered between sessions
Updater was integrated into PSPad. From the automatic check or from menu Help you can decide to download update manually or run updater. Updater can be started from command line too - see included ReadMe file in Updater folder.
HTML preview - it's possible to use WebView2 based on Chromium engine - in the HTML Preview switch engine using first icon in the top left. There is necessary to install WebView2 runtime from MS: developer.microsoft.com, or small MS installer what will do it automatically for you: go.microsoft.com
Changed library for handling INI files. Please report any problem with configuration files
InnoSetup Script highlighter - improoved highlighting
Open favourite panel from the File menu
SpellCheck - load/release dictionary
Program settings / KeyMap - save problem
Edited 1 time(s). Last edit at 2021-04-19 14:58 by pspad.
Posted by: brolx | Date: 2021-04-19 11:06 | IP: IP Logged
This version screws up all settings
Posted by: pspad | Date: 2021-04-19 12:03 | IP: IP Logged
brolx:This version screws up all settings
What do you mean?
Posted by: bluezero | Date: 2021-04-20 08:39 | IP: IP Logged
What he means is that settings get lost.
Background color for example.
Row numbers missing (toggled off)
Edited 1 time(s). Last edit at 2021-04-20 08:40 by bluezero.
Posted by: pspad | Date: 2021-04-20 08:55 | IP: IP Logged
There were problem with skin file - Carbon. PSpad tels you that Carbon isn't available.
When you select new dark skin, you got your "background" back.
This isn't "screws up all settings", sorry.
"screws up all settings" means PSPad destroys your PSPad.ini file and you lost all settings.
Posted by: blunzn | Date: 2021-04-20 13:32 | IP: IP Logged
I upgraded to build 597 today and had all my settings reverted to default PSPad values after first startup of PSPad. Luckily I had a backup of my original PSPad.INI settings file, once applying the backup file and restarting PSPad everything was back to normal.
In addition to that I have display issues with the tab bar since build 593, the tab headers sometimes vanish until I mouse-over them. Also I can't see all open tabs anymore as only one line of tabs is displayed (earlier builds had the tab area resize to multiple lines in case there were more tabs open than could be displayed in one line).
Edited 1 time(s). Last edit at 2021-04-20 13:33 by blunzn.
Posted by: pspad | Date: 2021-04-20 14:12 | IP: IP Logged
How did you do the update? Did you replace existing files as is mentioned in any developer build description?
In program settings set multiline tabs to see all files tabs.
Reset settings means you should delete PSPad.ini
Part of the any setup or zip isn't PSPad.ini file, it can't be replaced by updating.
Posted by: bluezero | Date: 2021-04-20 14:37 | IP: IP Logged
Same happened to me.
Restoring the PSPad.ini helped.
I did not replace the ini file when updating, nor deleted.
Posted by: bluezero | Date: 2021-04-20 15:38 | IP: IP Logged
Other thing i noticed after updating to 507:
Previously when i hit [ then ] was automatically added, but when i hit ] right after then it acted as if i have just written [].
But now it results in []].
The same happens with other brackets and quotes.
But it might be that it was caused by resetting the setting when updating to 507.
Posted by: pspad | Date: 2021-04-20 15:43 | IP: IP Logged
Yiu have active Bracket completion, but smart bracket completion is off. Activate it
