You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.6 (569) English
Posted by: pspad | Date: 2021-03-08 15:20 | IP: IP Logged
Download links:
SHA1 hash:
9b5f54fb1aa3a011e5ffd3577c495918ae7b6cf7 pspad506b569.zip
38b3703b8b23b7cd7aad78625667daaa98581ba6 pspad506b569x64.zip
Changes to 5.0.5 (561)
News:
Search/Replace dialog - optimization - when you start with confirmation and answer Replace all, following replace process skips all drawing and will be lightning fast
Undo and Redo optimized for big change number
Exception - added support to send report for mail clients without Simple MAPI support
If dark skin was used, the content of help was unreadable (black font on dark background)
TextDifference - fixed in 64 bit version
Hex Editor - fix for 64b version
Posted by: gwinkless | Date: 2021-03-11 11:01 | IP: IP Logged
Hi
New version appears to have inserted a 5-line-or-so gap between the menu and the main viewport.
Have I missed something?
Posted by: gwinkless | Date: 2021-03-11 11:22 | IP: IP Logged
The gap seems to have resolved itself. Was related to the number of tabs open when I first opened a project - the gap was the same size as the file tabs lines, as if the space for the tabs was double what it should have been, and even opening a new project didn't solve it (as you see); however when I closed a few files so the file tabs dropped a line, the gap disappeared, so it seems that the initial size calculation is perhaps in error but the later calculation is correct?
Posted by: gwinkless | Date: 2021-03-12 09:53 | IP: IP Logged
After hitting "undo" and "redo" my caret has stuck: the line is at the point of the redo, but moving the cursor doesn't move the caret. I assume this is related to the caret changes you made in the previous version?
Posted by: pspad | Date: 2021-03-12 10:23 | IP: IP Logged
Hello.
I have reported it already. Fix will be available this weekend
