You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.5 (561) English
Posted by: pspad | Date: 2021-02-21 16:18 | IP: IP Logged
Download links:
SHA1 hash:
a1fa0d45fbb7ad79d9195562949ff32ebf77c096 pspad505b561.zip
0649cd3576b72b610c3e940c5bb6068bb24a7a02 pspad505b561x64.zip
Changes to 5.0.5 (557)
News:
Tcl/Tk highlighter extended of new keywords from new version
Stability improvements
Autocomplete - removed brackets
Save file without file change (Shift+Ctrl+S) allows to set time difference. Usage e.g. for synchronized folders. Difference (in seconds) is added to existing File time. Parameter is in Program settings / Direct edit as SaveFileTimeShift variable, value (positive number) is in seconds.
Windows Shell script - small fixes
File tab color without Theme service enabled
Posted by: Ravelli | Date: 2021-02-25 21:28 | IP: IP Logged
Since 5.0.5(549) I'm getting two Access Violations when I open project files from the desktop under Windows 7 64 bit. When I hit the OK button on both of them, I can use PSPad, so far I know without any issues.
Screenshot 1, Error log 1
Screenshot 2, Error log 2
Friendly greetings
Ravelli
Posted by: pspad | Date: 2021-02-26 06:10 | IP: IP Logged
Thank you for report. I will rewrite part of the project loading what caused problem.
Posted by: Professor Bernd | Date: 2021-02-28 14:25 | IP: IP Logged
Off-Topic
Hi KaFu
from Professor Bernd.
Posted by: Professor Bernd | Date: 2021-03-01 01:22 | IP: IP Logged
Hello.
"Undo" does not work as expected.
Steps to reproduce
1. write a few words, then 10 spaces and a few more words.
2. put the caret after the ninth space and press enter. Then press the shortcut for undo and after that the shortcut for redo.
Example The dots represent spaces, the pipe represents the caret:
hello world!........|.hello world!
Result
hello world! hello wo
rld!
Edited 1 time(s). Last edit at 2021-03-01 01:23 by Professor Bernd.
Posted by: pspad | Date: 2021-03-01 04:08 | IP: IP Logged
Do you have trim yrailing spaces option in the program settings / editor active?
This edkitor component functtionality is strange sometimes
Posted by: Professor Bernd | Date: 2021-03-01 12:04 | IP: IP Logged
pspad:Do you have trim yrailing spaces option in the program settings / editor active?
The trim trailing spaces option is enabled in the editor.
This is strange. I just checked and the behavior has been occurring for a long time - but I never noticed it before.
Can you fix it or is it too much effort?
Posted by: pspad | Date: 2021-03-01 12:36 | IP: IP Logged
It's inside the editor component.
Trim trailing spaces behavior is strange, it trims when you leave the line (Enter, arrows, mouse)
When you connect it with enabled step behind the EOL (end of line), when you can put cursor anywhere behind the real line end and the position is virtual till you write some letter it's hard to fix it without break other functionality.
If you remember, I tried to fix inserting real tabs instead of spaces and it broke undo/redo and cursor positions (your last emotional e-mails)
Posted by: Professor Bernd | Date: 2021-03-01 20:27 | IP: IP Logged
When I think of a solution, at first I think it's not that difficult. Even with trim trailing spaces, you only need to remember CaretX before the line break happens and when you undo, you restore the text to position CaretX.
But then I realized, that's not all! There is to consider this and to consider that and much more, which makes the whole thing complicated.
After all, I didn't notice this problem for over 1 year. Let's just hope it's a very rare occurrence.
Thanks for the information!
Posted by: pspad | Date: 2021-03-01 21:14 | IP: IP Logged
I let it open. I need more time for it.
