You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.5 (561) English
#1 PSPad unicode 5.0.5 (561) English
Posted by: pspad | Date: 2021-02-21 16:18 | IP: IP Logged
Download links:
SHA1 hash:
a1fa0d45fbb7ad79d9195562949ff32ebf77c096 pspad505b561.zip
0649cd3576b72b610c3e940c5bb6068bb24a7a02 pspad505b561x64.zip
Changes to 5.0.5 (557)
News:
Tcl/Tk highlighter extended of new keywords from new version
Stability improvements
Autocomplete - removed brackets
Save file without file change (Shift+Ctrl+S) allows to set time difference. Usage e.g. for synchronized folders. Difference (in seconds) is added to existing File time. Parameter is in Program settings / Direct edit as SaveFileTimeShift variable, value (positive number) is in seconds.
Windows Shell script - small fixes
File tab color without Theme service enabled
#2 Re: PSPad unicode 5.0.5 (561) English
Posted by: Ravelli | Date: 2021-02-25 21:28 | IP: IP Logged
Since 5.0.5(549) I'm getting two Access Violations when I open project files from the desktop under Windows 7 64 bit. When I hit the OK button on both of them, I can use PSPad, so far I know without any issues.
Screenshot 1, Error log 1
Screenshot 2, Error log 2
Friendly greetings
Ravelli
#3 Re: PSPad unicode 5.0.5 (561) English
Posted by: pspad | Date: 2021-02-26 06:10 | IP: IP Logged
Thank you for report. I will rewrite part of the project loading what caused problem.
#4 Re: PSPad unicode 5.0.5 (561) English
Posted by: Professor Bernd | Date: 2021-02-28 14:25 | IP: IP Logged
Off-Topic
Hi KaFu smiling smiley
from Professor Bernd.
#5 Re: PSPad unicode 5.0.5 (561) English
Posted by: Professor Bernd | Date: 2021-03-01 01:22 | IP: IP Logged
Hello.
"Undo" does not work as expected.
Steps to reproduce
1. write a few words, then 10 spaces and a few more words.
2. put the caret after the ninth space and press enter. Then press the shortcut for undo and after that the shortcut for redo.
Example The dots represent spaces, the pipe represents the caret:
hello world!........|.hello world!
Result
hello world! hello wo
rld!
Edited 1 time(s). Last edit at 2021-03-01 01:23 by Professor Bernd.
#6 Re: PSPad unicode 5.0.5 (561) English
Posted by: pspad | Date: 2021-03-01 04:08 | IP: IP Logged
Do you have trim yrailing spaces option in the program settings / editor active?
This edkitor component functtionality is strange sometimes
