You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.5 (557) English
Posted by: pspad | Date: 2021-02-14 17:31 | IP: IP Logged
Download links:
SHA1 hash:
9e08df0a88d9a96f894a6e8233451344299c0636 pspad505b557.zip
c9d5f5ee97f812222fec41be07abf6b964c88990 pspad505b557x64.zip
Changes to 5.0.5 (555)
News:
PSPad remembers last used tab from left panel
Automatic corrections (menu Settings / Spell settings) - new option - Maintain char case.
Automatic corrections (menu Settings / Spell settings) maintain case of correction if option enabled. E.g. if defined dt = document, then Dt will be replaced to Document, DT to DOCUMENT
PowerShel 5.1 - new user highlighter definition including code clips
Edit favorite link - for each edit new button with variable list was added instead of right mouse
Select inside brackets works for « and » too
Handled exception when reading proxy server information from registry
XML Code explorer - CDATA caused broken structure in some cases
Autocomplete - sometimes replaced more text
