You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.5 (555) English
#1 PSPad unicode 5.0.5 (555) English
Posted by: pspad | Date: 2021-02-09 15:02 | IP: IP Logged
Download links:
SHA1 hash:
a9dd9ab4bdac85e952c5e4a46da8d213b2c3da45 pspad505b555.zip
3ca1194872a0ea8422bde5eda5d2844bebac0c84 pspad505b555x64.zip
Changes to 5.0.5 (553)
News:
Added basic application version analytics. In program settings / Program 2 you can switch it off, there is info showing what data are send. It's simple HTTP request only, you can cach it and check it. No sensitive information are sent, only one time request.
Delete libraries libSoftMeter.dll and libSoftMeter64.dll, they arn't used
Autosave files when close PSPad - new option in Program settings / Backup
Automatic corrections (menu Settings / Spell settings) maintain case of correction. E.g. if defined dt = document, then Dt will be replaced to Document, DT to DOCUMENT
Problem with multiple play macro containing clipboard manipulation
